tip.....
after cursing the design of gear oil containers [one litre] with the pull-out spout which requires contortionist abilities and powerful fingers/hands to squeeze the stuff out, solved the problem...
discard or cut off the spout.....drill hole on the sealing cap, insert about 500mm of clear plastic tubing as a tight fit in the hole and to reach the bottom of the container......use a quick clamp [bar type] to squeeze the container.....easy!
fred
fred
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
I use one of these. Works a treat but I'm not sure if you can obtain them outside Australia.
https://www.stm.net.au/hand-pumps/1-lit ... b-oil-pump
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
My method on my +2 is to fit a long plastic tube down into the engine bay and into the gear box filler access,
then open the gear oil bottle and fit the end into the plastic tube, hang it from the garage beam and let it drain into the gearbox. Tube is about 12mm ID
Then go and have a cuppa
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
I made a pressurized one from an old but sturdy petrol can and a schrader valve, it now has a very interesting shape like it has eaten all the pies!!! The drawback is that it keeps pumping o?l until I can release the pressure so it gets messy when the o?l level reaches the filler hole and starts overflowing.
That one looks like a proper mechanical pump and the stub to drain back the excess o?l is a great idea, I would buy one in a heartbeat if they are available in europe, anyone sees them on E-bay please post the link.
- Chancer
This works a treat for me:
https://www.machinemart.co.uk/p/cgg500- ... 0wodrxcDiQ
I actually bought it to bleed the oil feed to the central heating boiler when it ran out of kerosene, but it's then become very useful ineed in the workshop
Jon
Jon
- jono
2cams70 wrote:I use one of these. Works a treat but I'm not sure if you can obtain them outside Australia.
I use the same - perfect for the gearbox and diff on the elan and plus 2 and also other cars such as diffs and transfer case on the Landcruiser and transaxle on the Esprit
This UK pump looks similar to the Australian Tom Thumb pump, though not exactly the same. https://www.amazon.co.uk/Draper-FHP-1L-23242-Multi-Purpose/dp/B008YFX1S6
Robert
- rcraven
ok
so you guys are way ahead of me......
in defence of my contraption.... cost = 0 as I had the plastic tube and clamp already.....
easy to stop immediately and one-handed operation!!
fred
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
Fred, cost of $0 hard to beat!
Having had a boat, any marine dealer has a simple pump thing that screws onto a standard gear oil plastic container, not expensive as I recall.
They are used to fill the outdrive for winter storage as you pump the oil in from the bottom and vent to the top, to be sure water is not left in the drive over winter.
Gave up the boat as get enough sun in the Loti, my preferred, and original interest.
Jack
Jack
- jk952
