Re: 5 speed selector
Thu Apr 06, 2017 1:29 pm
Fri Apr 07, 2017 8:59 am
by vernon.taylor
I guess David must understand - I don't.
Fri Apr 07, 2017 6:43 pm
Come on,wake up Vernon...a home-made tool for removing the gear lever ball fixing,along with how to modify your gear lever and which " nut " to remove to reduce 5th/reverse "notchiness"
Tue Apr 11, 2017 2:12 pm
by vincereynard
john.p.clegg wrote: which " nut " to remove to reduce 5th/reverse "notchiness"
That is new to me. Would you care to explain further. 5th / reverse notchiness , and the reduction of same, is of current interest.
Quite how using, what appears to be, a stethoscope on a stick helps is a mystery!
Vince
Tue Apr 11, 2017 2:45 pm
Vince
The bottom of the gearbox houses the spring detent for 5th/reverse,by packing it out you can reduce the " notchiness ",but not too much...you don't want it jumping out of gear.
as for the stethascope that's used to check if I'm still alive from time to time....
Wed Apr 12, 2017 7:21 pm
by vincereynard
Ah, but how much is too much? That's the question. I'm often accused of going too far!
(Do you mean the big brass dome headed one next to the oil drain? It looks very important!)
Wed Apr 12, 2017 7:55 pm
It is important,it holds the car in 5th/Rev gear,as for how much is enough I'd take it out and count the threads,fit a copper washer with the thickness of a thread and see how it feels,repeat.
Fri Apr 14, 2017 6:04 am
by nmauduit
john.p.clegg wrote:Vince
Jumping in - rather than out : I've occasionally experienced a fifth difficult to get out of gear on a "professionally" rebuilt gearbox (from a low mileage gearbox). I've not used the fifth very often, only on highways then also because of that, with plenty of time to pull back to neutral.
Would a overly strong spring (or possibly missing/inadequate washer) be a cause of that kind of behavior? I guess one has to drain the oil every time one want to experiment with a different thickness washer...
Fri Apr 14, 2017 6:13 am
I don't think one has to drain the oil,the spring works via a " torpedo" detent on the reverse/5th selector shaft and any oil lost would be minimal..
Fri Apr 14, 2017 11:27 pm
by nmauduit
john.p.clegg wrote:I don't think one has to drain the oil,the spring works via a " torpedo" detent on the reverse/5th selector shaft and any oil lost would be minimal..
that sounds excellent news : I've scheduled a day on a 4 post lift to tidy up the underneath of my car later this month, I will gladly take advantage of it to give a close look at that spring in case it may help improving downshifting 5 to 4 and hopefully expending its use...
Sat Apr 15, 2017 9:05 am
by vincereynard
I've had a go but by 'eck it is tight!
I'll have to search for a better socket and employ my "persuader" bar.
My idea is to crack it off then slowly undo it a flat at a time, testing the gear selection until a difference is felt. The box is standing upright on the floor at the moment so now would seem an opportune moment to experiment.
Mon Apr 17, 2017 9:34 pm
I've just done this while I had the car in the air. My bolt wasn't particularly tight but box is in the car so easily to get leverage.
A few things to note for other considering doing this:
- It's a 5/8" washer
- Mine leaked some fluid, around 1hz of large drops after initial larger flow nothing to prevent you doing this
- The detent didn't drop immediately but did so you need to track if/when it drops, you don't want to lose it!
- Pretty straight forward job, re fitting slightly tricky due to needing to compress the spring to get teh bolt to start in the thread
My original copper washer was ~1mm, I fitted a ~1.5mm as that is what I had to hand. Feels a bit better but still a little stiffer than 1/2/3/4, weather isn't suitable so haven't given it a test drive yet...
Tue Apr 18, 2017 11:34 am
by vincereynard
I had a play and unwound the nut 1 flat at a time. The notchiness improved between the 5th and 6th flat. The gap to the existing washer was approx. 1.4 mm.
As John suggested in the beginning - one full turn!
Tue Apr 18, 2017 11:48 am
Please bear in mind the tortious route from the gearknob to the selector, and the fact that all else could play a part in causing difficulty in selecting 5th/reverse...a little bit of play here and a little bit of play there all adds up..
Tue Apr 18, 2017 8:09 pm
by nmauduit
john.p.clegg wrote:Please bear in mind the tortious route from the gearknob to the selector, and the fact that all else could play a part in causing difficulty in selecting 5th/reverse...a little bit of play here and a little bit of play there all adds up..
I'll be happy to take in and learn from any hint/advice, esp. regarding disengaging (which is what is more difficult/troublesome on my car) ...
