Gearbox selector ring thickness
PostPost by: Martingtese5a » Sat Feb 18, 2017 5:06 pm
Hello all, I just finished rebuilding my 4 speed gearbox on my S4. I now want to install the threaded cup that is holding the selector shaft ball. I understand that there needs to be a ring betwen the base plate and the threaded cup/holder. Does anybody know the thickness of this ring. I believe the thickness is critical to a correct reverse operation. Thanks in advance.
Martin
Martin Stelleman
1969 Lotus Elan S4
1972 Reliant Scimitar GTE SE5A
1978 TVR 3000S Turbo
Martingtese5a
New-tral
PostPost by: CBUEB1771 » Sun Feb 19, 2017 7:35 pm
You should only have to use the paper gasket supplied with your gasket set. I just checked mine which measures 0.025 inches thick and I can select reverse with no problems. There was a thread here not long ago in which people reported quite a range in the thickness of this gasket. I am not sure that the makers of replacement gaskets pay much attention to the correct thickness of this item.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: Martingtese5a » Sun Feb 19, 2017 8:23 pm
Hello Russ, many thanks! Thats what I am looking for. That gasket was not in my set but I have different sizes paper and will use your suggested thickness and check operation. Will let you know the result. Cheers!
Martin Stelleman
1969 Lotus Elan S4
Martingtese5a
New-tral
