Ford 2000E gearbox roller bearings
Hi Guys,
20 years ago I rebuilt my gearbox and at the time I installed input and mainshaft roller bearings heavier duty than standard - i.e containing more balls than the original but still single row. They were German FAG bearings. FAG were able to offer the same bearing size in both standard and heavy duty specification and I chose the heavy duty type.
I now wish to put this gearbox back into service. When I last used the gearbox 20 years ago it was only in the car for a week after rebuild before the car it was in was unfortunately written off through no fault of my own. It worked well for a week but not enough time to ascertain whether these bearings were a good long term choice or not.
My concern now older and wiser is that like most thing in engineering you don't get something for nothing and with bearings the trade off is load rating versus speed rating - i.e higher the load rating the less the speed rating because of increased friction. The engine I am planning to put this gearbox behind has much higher RPM potential than standard.
So my question is - does anyone have any experience of heavier duty bearings in the 2000E box? Does anyone have the dimensions or type designation of the standard bearings (i.e bearing code stamped in the outer ring)?
I don't have any bearings on hand at the moment that I can check and I don't want to have to pull the gearbox apart unless I have to. Even with the codes of the standard bearings I may be able to contact FAG to find out exactly what the heavier duty version bearings are and their ratings.
I remember the heavier duty bearings had a notch in the side of one or both bearing races presumably to help with the insertion of more balls during manufacture.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
2cams70 wrote: Does anyone have the dimensions or type designation of the standard bearings (i.e bearing code stamped in the outer ring)? .
I cant tell you anything about the heavy duty bearings but I just replaced the bearings on a 2000e box with standard bearings as listed below.(links shows the dimensions)
Although these are SKF bearings I believe FAG bearings use the same numbers ie:
6206 NR and 6305
front
https://simplybearings.co.uk/shop/produ ... oCdb3w_wcB
rear
https://simplybearings.co.uk/shop/produ ... oC7_jw_wcB
Thank you for that information. Based on this I believe I have determined what they are:
Front bearing: 6206 (standard), BL206 (high capacity)
Rear bearing: 6305 (standard), BL305 (high capacity)
From an NSK catalogue the ratings are:
6206 - load rating (static): 19,500N, load rating (dynamic): 11,300N, limiting speed: 13,000RPM
BL206 - load rating (static): 21,000N, load rating (dynamic): 16,300N, limiting speed: 12,000RPM
6305 - load rating (static): 20,600N, load rating (dynamic): 11,200N, limiting speed: 13,000RPM
BL305 - load rating (static): 21,500N. load rating (dynamic): 15,500N, limiting speed: 13,000RPM
Based on this I don't think I have a problem and they seem to be a worthwhile upgrade with only a bit of extra friction as a tradeoff.
- 2cams70
