Lotus 5 speed shifter
• Page 3 of 3 • 1, 2, 3
Again I'd appreciate that Vince. My current ball is still currently serviceable but is going to fully disintegrate at some point. So would be good to be able to get a replacement ahead of it's complete failure.
Stick replacement options are pretty limited on this side of the pond...
- mbell
I've just drained the gearbox oil and it is as black as pitch. There is very little actual plastic bits in the oil still recognisable as such.
Presumably A/ the oil has not been changed in quite a while. B/ It has been coloured by the disintegrating plastic (again over quite a while!)
I'll flush it out with some more oil and see how much more comes out.
Hopefully just letting it run for 10 minutes in neutral should splash it round enough. I filled the box through the gear lever housing, another advantage of having it easily detachable.
- vincereynard
