5 speed input bearing / bushing
Posted: Fri Jul 15, 2016 11:02 am
I'd like some thoughts on the part that goes into the flywheel to accomodate the shorter input shaft of a
Lotus 5 speed. Is there any downside to using the 4 bolt crank bushing, turned down to fit a 6 bolt crank
flywheel? It's a really tight fit, needing a press to do the job.
Or should the Lotus part made specifically for this purpose be used? Sounds like the right answer but
any reason why the bushing can't be used?
