Drive Shaft Outer - Bearing Orientation
PostPost by: Gazzerb » Sun Nov 29, 2015 3:58 pm
I am in the process of rebuilding my rear struts and refitting the outer drive shafts with new bearings.
Before I go too much further I would like to check that the inner bearing is the correct way round. I have fitted this with the extended inner part of the race projecting outwards towards the small circlip and hub etc. This is as my disassembly notes from many years ago and appears to be as shown in the Workshop manual.
Would someone please confirm this is the correct orientation.
Many thanks
Gary
dsc_0307.jpg and
dsc_0305.jpg and
Gary
1972 Elan +2 S130/5
2001 Elise S2
Gazzerb
PostPost by: rgh0 » Sun Nov 29, 2015 7:27 pm
Yes that is correct
PostPost by: Gazzerb » Sun Nov 29, 2015 8:49 pm
Many thanks.
I can now progress with confidence!
:D
Gary
Gary
1972 Elan +2 S130/5
2001 Elise S2
Gazzerb
PostPost by: alan.barker » Mon Nov 30, 2015 12:21 pm
before fitting bearing be sure to put in place the Dust Sheild :wink: :wink:
PostPost by: Gazzerb » Mon Nov 30, 2015 7:20 pm
It would have been far too easy to forget but I did remember to slide on the large circlip and dust shield before fitting the bearing! They are just about visible in the photos. :P
Gary
Gary
1972 Elan +2 S130/5
2001 Elise S2
Gazzerb
PostPost by: alan.barker » Tue Dec 01, 2015 8:34 am
hi Gary,
that's good news. Sometimes you need to trim the rubber seal on the bearing very carefully with a Stanley knife. This helps when assembled to put the dust sheild and big circlip in place.
good luck
