5 speed to 4 speed conversion
• Page 3 of 3 • 1, 2, 3
Toomspj,
Do the non- standard size tyres clear the arches etc - or does it cause body / suspension fouling / issues ?
What sort of wheels do you have fitted ?
Did you convert to narrow springs, perches etc. ?
What make of tyres are you using. ?
Phil.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
Hi Phil
The 165/70-13 tyres fitted without having to adjust the body and with standard springs. The previous owner had used his portable press (hammer) to slightly flatten the spring retainer, although I'm not sure it was necessary.
I've since fitted narrow springs (2 years ago) in order to be able to change spring rate easily and to adjust ride height - I went for 100 lb springs all round which is in my opinion a good compromise.
The tyres are Dunlop D83J tyres, which have been reintroduced as historic tarmac rally tyres - I wouldn't go out of my way to recommend them. When they were first fitted to my car I think they were in use as circuit tyres. I am about to change them out, probably for Michelin XAS FF as the Dunlops are pretty lethal in the wet and are pretty much worn out after nearly 10 years!
If you have narrow springs you should be able to fit 175 section tyres - we use 175/60-13 Yokohama A048 for racing on standard shelled S3 and S4 cars but on 5 1/2" rims. (They will comfortably fit on a 5" rim). I personally don't like the look of Yokohama's on a 1960's car. So a 175/70-13 could be another way to increase gearing
Above all, just relax and enjoy the revs! Mind you I always drive with the top down - it's pretty noisy with the hood up.
Paul Tooms
Paul Tooms
Turning money into noise!
- toomspj
Phil matey,
I think you've been spoiled by the comforts of modern motoring and may never really enjoy an Elan because of this. It's not classic driving but it is a really nice place to be - but go have a look at and drive an SLK. I've got the 1.8 supercharged 6 speed manual. Fold away roof, heated seats, air scarf very little to dislike about if. It's all about enjoying your car and if you don't really enjoy the Elan then pass it onto to someone else and move on. Doesn't stop you admiring or desiring an Elan but maybe it's just not for you??
elanfan1 - Coveted Fifth Gear
l10tus wrote:Steve,
Maybe I enjoyed the rebuilding, more than I do driving it ?
Maybe a bit quieter with that sill painted black??
Seriously though Phil give it sometime and enjoy the noise on short blats!!
