Where is the drain plug on the diff?
Sat May 10, 2014 4:25 pm
by dgently
Manual says "lower right front of the housing" - can't see an obvious candidate obvious candidate on the nose casing of my '68 +2.
I understand from the archives that not all diffs were fitted with drain plugs. But can anyone describe it's location - it's not on the illustration
Thanks in advance!
Re: Where is the drain plug on the diff?
Sat May 10, 2014 4:32 pm
by elanner
It's in the rear cover, facing forward, right hand side. Not in the nose.
Nick
Sat May 10, 2014 10:25 pm
by dgently
Sincere thanks Nick, that's crystal clear. Will check again, but I am pretty sure my diff doesn't have one of those.
Sun May 11, 2014 1:31 am
The filler cap is fairly hard to get to from underneath the car and to top up you need an oil bottle with a 6 inch (at least) tube on the cap.
Personally I modified my car by using a cup saw drill to make a 3 inch hole in the wall of the boot near the filler cap.
The cap can then be opened from within the boot.
The hole in the boot wall is filled with a large blind grommet when not in use.
I don't recall seeing a DRAIN cap; I presumed one had to siphon out the old oil for an oil change.
Sun May 11, 2014 2:34 pm
by peterexpart
billwill wrote:The filler cap is fairly hard to get to from underneath the car and to top up you need an oil bottle with a 6 inch (at least) tube on the cap.
And even better than that you can also set the Handbrake correctly !!
Sun May 11, 2014 3:19 pm
by dgently
The drain plug WAS there after all.
Don't have access to the filler through the boot and likely to end up with multiple holes if I try to cut one
Got at it from the left and used my brake bleed kit to pump the oil up into the filler. It worked well, slow but easy and tidy.
Thanks for the help!
Sun May 11, 2014 5:27 pm
by archigator
Here's an earlier post showing how I addressed my differential access problem...
http://www.lotuselan.net/forums/lotus-gearbox-f37/easy-access-the-diff-t15877-15.htmlGary
'71 Sprint FHC
Miami, Florida
Mon May 12, 2014 5:52 pm
by dgently
Hmmm, the access hatch looks like the way to go alright, even I could locate it over the earthing point.
Is it worth cutting one in the forward transmission tunnel for the gearbox?
Tue May 13, 2014 12:31 am
I don't think it's worth it for the trans. Another hole in the frame is not good and the fill plug is accessible from below and filled from above, not easily but easier than the diff.
Greg Z
Tue May 13, 2014 1:36 am
There is already a side hole in the transmission tunnel.
Take out the right hand seat and lift off the Tunnel padding and carpet and there it is.
You need it to get the prop shaft into the back end of the gearbox.
Sat Aug 01, 2015 3:28 pm
by posulliv
I found this thread extremely useful, so I'm adding to it for others.
There are indeed some diff carriers that don't have a drain plug. Pictures of mine below.
I thought I was screwed when my normal gear oil suction tool was too big to fit into the fill hole.
Then I remembered I had an engine oil siphon and it did the trick.
It took several passes to drain the diff fully, I kept having to reposition the take-up. Eventually it did work.
Picture of tools needed for trans and diff fill also shown.
In my case the wrenches were 18mm open end for diff fill, 15mm open end for trans fill, and 11/16s 12-point box for the trans drain.
