Speedo Right Angle Drive Disassembly?
Wed Apr 23, 2014 3:23 pm
by JGeezer
I sourced a right angle drive - finally - but of course it has a busted input quill.
I am willing to attack this, but how the heck do you get it apart, and get the old quill out?
I seem to recall a pic of a dissembled drive I saw once, but I have been searching our fora for some time and can't come up with it.
Thanks for any help.
Re: Speedo Right Angle Drive Disassembly?
Wed Apr 23, 2014 3:42 pm
Wed Apr 23, 2014 5:05 pm
by JGeezer
types26/36 wrote:http://www.lotuselan.net/forums/lotus-gearbox-f37/speedo-angle-drive-t15817.html
That's the one, thanks! Don't know why but I just could not find it myself.
Thu Apr 24, 2014 7:24 am
by jono
...does the quill not just pull out of the drive, as a push/interference fit?
I recall changing one on a Caterham which has a very similar (if not identical) angle drive and this is how it worked.
Be Interested to know as my speedo has just stopped working and this is what I suspect is the cause.
Jon
Thu Apr 24, 2014 3:59 pm
by nigelrbfurness
The quill is indeed a push fit. If you can't find a replacement quill, I have succesfully used 1/8" welding rod shaped at both ends with a file. Mifht be possible to make up one from a section of old speedo cable inner, treated to a dose of braze or silver solder at each end then shaped to fit.
Nigel F.
Thu Apr 24, 2014 5:10 pm
by JGeezer
jono wrote:...does the quill not just pull out of the drive, as a push/interference fit?
Jon
Mine is not apart yet, but it sure doesn't feel like it will pull out, and other member have mentioned drilling out the old quill from the gear.
I would think a decent design would be as you think, with a pressfit square hole in the gear and a quill long enough to stay engaged at both ends (assuming there's a limit to how far in the transmission end can go). Then you could just replace a broken one with no drama.
I will report more.
Thu Apr 24, 2014 5:14 pm
by William2
I have been led to believe that the quill available from Caterham Cars may be suitable. Otherwise Susan Miller can get the units repaired. She did mine recently.
Fri Apr 25, 2014 8:37 am
by jono
I did mine last night but it turned out to be the new speedo cable and the angle drive and quill were fine, much to my surprise.
I think I had the cable at too tight a radius in the back of the dash and this must have stressed it.
Incidentally I spoke to Susan yesterday and she no longer does exchange angle drive units as folk kept sending her 'exchange' units which we either off another type of car or otherwise incomplete/incapable of re use. I thought that was a great shame and a betrayal of trust - I would have held the miscreants to account if I'd been her
Jon
Fri Apr 25, 2014 4:40 pm
by alan
in the past i repaired one. I removed the staking in the alloy body and then removed gear complet with quill. I then replaced the quill with a short length cut from an inner speedo cable. You can form a square on the quill by heating to cherry red and shaping with hammer, very easy
Fri Apr 25, 2014 5:17 pm
by JGeezer
alan wrote:in the past i repaired one. I removed the staking in the alloy body and then removed gear complet with quill. I then replaced the quill with a short length cut from an inner speedo cable. You can form a square on the quill by heating to cherry red and shaping with hammer, very easy
I finally got mine apart, and I assume you had to drill out the old quill stub. There have been suggestions here that it's a press fit into the gear, but I certainly can't drive it out.
Sat Apr 26, 2014 6:58 am
by alan
if i remember correctly, i used heat also when drilling out the quill. To fix the quill in the gear i think i brazed it in the gear. Sorry not to be clearer as i did this maybe 30 years ago
Sat Apr 26, 2014 5:57 pm
by JGeezer
JGeezer wrote:jono wrote:...does the quill not just pull out of the drive, as a push/interference fit?
Jon
I will report more.
I was wrong, it
is a press fit. I don't think anyone has shown how the quill fits in the gear before:
Sun Oct 18, 2015 7:22 pm
by robertcowie
[quote]
My mangled quill is now out and looks just like the photo provided by jgeezer. So how to fix or replace it? Is the 'quill' that entire assembly, i.e. the short piece of speedo-like cable plus the cylindrical piece it is attached to and that is s slide fit into the barrel of the gear, or is it just the piece of cable, which does not seem to want to come out of the cylindrical part? I am assuming the former.
If so, is it still available from Caterham? I will contact them.
If not, if the part includes the cylinder, then how do you get the speedo-cable-thing out of the cylindrical part?
Thanks for any help!
Robert Cowie
1969 Elan +2 (federal 50-2504)
1974 MGB (chrome bumpers)
Mon Oct 19, 2015 3:29 am
by 7skypilot
I had the same problem on my S4. Speedograph-Richfield repaired it perfectly and at a reasonable cost and swift turnround.
They also stock a 'new' version which will exactly replicate the original in function, but looks a little different:
http://www.speedograph-richfield.com/html/rgb2402.html I don't think the Caterham angle drive fits as the cable square input is a different size. I tried using a spare from my Caterham but the fit was intermittent.
Hope this helps...
Mon Oct 19, 2015 3:32 am
by 7skypilot
I've just realise that you're not ideally placed to deal with Speedograph-Richfield who are in Nottingham, UK but if all else fails I know they deal with customers world wide. Might be worth a try...
