ZF Gear box
Hello,
I have a ZF gearbox originally on a Scimitar Coupe (1996 straight 6)
I'm told is can fit a Lotus, but I don't know which one. It's a 4 speed box.
Can anyone help? It is worth anything?
Nick
Nick
- vibrodolly
I can't image that the ZF S4-12 that was fitted as an option to the Type 14 Elite from perhaps 1959 to 1963 would be the same as that fitted to a 1996 Scimitar. Does it look like the attached? I don't think Scimitars were made as late as 1996.
- Attachments
- ZF S4-12.pdf
- (310.63 KiB) Downloaded 686 times
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
I had a quick look on the net and I think it's a Scimitar 996 model made in 1964, but the ZF was mated to the back of a six cylinder engine and had an overdrive option so I don't think it's going to the be same as the Elite box - I could be wrong though.
Mazzini - Coveted Fifth Gear
Is it a ZF 5 speed (ZF S5-18/3) or 4 speed? 4 speed ZF were fitted to some early elite
. The S5 will work in an elan with the correct bellhousing and shift setup. They are avaiable with 1;1 fifth or .795 fith.
James
Later Note: Sorry upon review, i see it's a 4 speed
James
Is the car a Scimitar or Sabre? My 1964 Sabra GT has the same ZF gearbox that was used in the Type 14. It has the same ratios as the close ratio Elan, 2.53 first, etc. Must have been where Colin got the idea for the early Elan transmission's ratios.
Rob Walker
26-4889
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Hi Nick - long shot as this is an old post but did you get rid of the gearbox? If not I'd be interested in having a chat as need one for my resto.Thanks Pete
- cheekymonkey
