Differential Wear Query
Posted: Thu Feb 21, 2013 4:37 pm
I've obtained a spare 3.9:1 diff unit (nose only).
(Using the Osprey book "How to Restore Gearboxes and Axles" as my guide) the diff appears to be in good condition with no marks that I can see on any of the teeth.
What it has got though, is slight movement of the pinion before rotational movement is transmitted to the crown wheel.
I would estimate that at the maximum movement at the perimeter of the diff flange is perhaps 1mm before the crown wheel turns.
So my question is - is this normal?
And am I correct in thinking that a slight tightening of the pre-load will eliminate the movement by removing float at the bearings?
I make this assumption (which is probably wrong) after reading this article I found on the web:
http://bernardembden.com/xjs/diff/index.htm
It's about a Jag diff but the techniques are relevant.
