Gearbox reverse switch
Hi Steve,
Are you trying to remove the gearbox ? This isn't necessary to get to the reversing light switch although it is a bit of a struggle. You don't say if you have an Elan or a Plus 2 but I would think both cars are similar - on the Elan you can access the switch from the engine compartment to undo the locknut and unscrew the switch from the gearbox for repair on the bench.
Take care when refitting the switch not to screw it in too far or it will prevent engagement of reverse gear.
S4 DHC
S4 DHC
- oldelanman
Could it be a 5 speed box?
types26/36 wrote:Could it be a 5 speed box?
Good point Brian.
Steve, if it is a 5 speed box ignore my post, I am refering to a 4 speed.
S4 DHC
S4 DHC
- oldelanman
Steve, I did a bit of a bodge on my MT75 by positioning a lever action microswitch under the console that is actuated by the shift lever. I did it this way because the reverse switch for the MT75 is NLA and I needed something for MOT. My shift pattern has reverse down and to the right, so it worked out OK.
Stu
1969 Plus 2 Federal LHD
This discussion reminds me of something else I need to sort out. I seem to remember,when fitting an exchange gearbox,( in about 78),that it had no reversing light switch fitted. No need to worry,I thought at the time,I can fix it out later! I'm pretty sure it is not a MOT fail,does anyone know for sure?
Ray
Ray
- Oldthumper
Oldthumper wrote:This discussion reminds me of something else I need to sort out. I seem to remember,when fitting an exchange gearbox,( in about 78),that it had no reversing light switch fitted. No need to worry,I thought at the time,I can fix it out later! I'm pretty sure it is not a MOT fail,does anyone know for sure? Ray
Basingstoke isn't TOO far from Worthing!
This outfit seems to know: http://www.basingstokemotandtyrecentre. ... ation.html
Quote: "What don't I need for an MOT test" - their list includes reverse lights.
The site also refers to VOSA:
http://www.dft.gov.uk/vosa/repository/C ... efects.pdf
Can't find any mention of reversing lights in operation...just their mounting and whether the reversing lamp indicator is working, or not.
I believe, therefore, if the fix was to fit a manually operated switch it would have to include a warning light in the wiring if not in the switch itself...
Cheers - Richard
- ardee_selby
There is a Piston Head thread about it here: http://www.pistonheads.com/gassing/topi ... 2&d=0&nmt=
and I believe if they are fitted they have to work but if not fitted it is not an MOT issue......although EU regs may now require them
Tried agin today to release the gearbox mount but the two bolts left holding the cross member just turn freely without undooing obviously the nuts on top of the bracket are not captive.
I cannot see or get to them, the car has a Spyder chassis and i cannot see any mehtod of gaining access to un do them.
Has anybody got any idea's
- potleyu18
Steve,
Sorry I cant help but try posting the question in the Plus Two section as you may get more responses.
Hi Steve,
Yes the nuts above the mount are not captive or integral to the mounting plate, you'll need to get a spanner in there! It's a very tight squeeze but I have big hands and managed to get a spanner on the nut with some manual dexterity. I also had to do the same to fix my reverse light, careful if your removing the switch completely (use the lock nut to mark how far into to screw it when putting it back in and be prepared for the flow of oil out the gearbox or have a same sized bolt ready to hand to block the oil flow.
Innes
Innes
Innes
1965 Elan S2 (26/4681)
1973 Elan+2S 130/5 JPS
innesw - Third Gear
I need a reverse switch as illustrated by oldelanman. Anyone know a supplier in Canada or the US. Thx.
Alain
Alain
MyLotus - First Gear
Hi Alain,
RD Enterprise in the US has them. http://www.rdent.com/
Spool down toward the bottom of the Elan parts list.
Colin.
Colin.
MyLotus wrote:I need a reverse switch as illustrated by oldelanman. Anyone know a supplier in Canada or the US. Thx.
Alain
'68 S4 DHC
- fatboyoz
