half shaft conversion length
Tue Jul 31, 2012 3:59 pm
by zeteclotus
Hi, I made some TT style conversion shafts for another +2 I had but can not find the drawing I made.
Does anyone have the min max length dimensions of either the CV type or TT hardyspicer type.
hopefully someone has either a pair off a car or maybe has a drawing?
I remember the PCD of the output shafts is 95.8mm.
I have decided I am not prepared to pay ?90 each and spend a day changing rotoflex couplings every 6-12 months.
Also I want to make my own shafts so i can leave the fail safe pegs on the car rather than cutting them off.
Thanks in advance.
Paul
Re: half shaft conversion length
Tue Jul 31, 2012 5:23 pm
by vernon.taylor
Salut Paul
I probably won't be the last to ask, but I am the first - would you consider making an extra pair to sell (to me) ?
Vernon
Wed Aug 01, 2012 6:16 pm
by elj221c
A search will give you this and doubtless others.
elan-mods-f31/elanmac-conversion-t24920.html
Wed Aug 01, 2012 8:08 pm
by Higs
Paul
Are you planning to shorten some driveshafts (by friction welding? by welding / sleeving?) or getting some custom ones made. I would be interested in joining in on this - I could get mounting plates made in bulk etc..
Let me know if you are interested....
Richard
Thu Aug 02, 2012 2:35 pm
by zeteclotus
I bought individual bits welded them together and had them balanced like you would for a custom prop shaft.
last time I used standard hardy spicer flange joints weld yolks and a sliding joint. +2 adapter plates I made out of 8mm plate, all worked well I just wish I had kept the drawings.
The engine output was at least 145BHP I did replace the diff output shafts with some later type ones.
Hi Richard yes I would consider making a small batch alone or with someone, only thing is for a one of i will probably go the hardy spicer joint route but for a bigger batch I think CV joints are better
Thu Aug 02, 2012 3:18 pm
Thu Aug 02, 2012 3:24 pm
Whereas mine are...just the same but with both ends sliding and covered in protective rubber..
[attachment=0]right rear drive 2.JPG[/attachment]
Thu Aug 02, 2012 3:29 pm
by zeteclotus
yes the ebay ones are very similar to what i made last time.
Thu Aug 02, 2012 3:35 pm
The ebay ones are what I started with,but felt two ends the same would be better,so ground out the weld,sourced some splined bar and fitted centralising springs in each end...have a couple of spare H/S joints mounted on ali adapter plates in the shed so should either end loose a U/J it's a twenty minute job to replace...
Thu Aug 02, 2012 8:36 pm
by c42
Hi All
Try talking to these guys,
http://www.davemacprops.com/dmphome.htmlAsk for John he is very helpful, no connection etc etc.
Sun Aug 05, 2012 9:22 pm
by lotusS2guy
Hi John
What's the story with the crenelated rear brake disk shown in your photo?
Herb
Mon Aug 06, 2012 5:42 am
Herb
ABS...
Mon Aug 06, 2012 7:08 am
by vernon.taylor
Salut Paul and Richard
An up to renew and show my interest. You'd make some grateful guys (and gals).
Vernon
Wed Sep 19, 2012 10:29 am
by zeteclotus
To answer my original question
393mm from hub 3 way mount to diff 3 way mount at maximum drop for a late car with failsafe shafts.
Finally finished making them and fitting them, got the new MOT yesterday.
As I recalled ok for a one off make but too much finishing work is needed on some of hardy spicer forgings to stop interference at maximum droop and all the bolts are custom thread lengths etc.
I manage to make the shafts so the failsafe pins are retained.
Has one else noticed losing the rotoflex coupling makes the car feel faster! especially noticeable from 0-30. I wonder what the power loss is of rotoflex couplings.
The car is quieter so I managed to make them more balanced than the original shafts.
on the down side the exhaust smell is back.....
Wed Sep 19, 2012 6:37 pm
by vernon.taylor
... so no production run, I guess ?
Vernon
