Difficulty inserting clutch slave cylinder pushrod.
Mon Jul 30, 2012 8:03 am
by AChen
Ongoing issues with the S4 restoration. I can't seem to get the clutch SC pushrod in place, even with the nuts turned all the way back on their threads. Not much play in the clutch fork.
Engine, bell housing, tranny all assembled and on the chassis. Body on chassis as well. Afraid something is wrong in the bell housing and I will have to tear this all apart. Maddening.
Any suggestions before I turn to my little helper pills?
Tony
Re: Difficulty inserting clutch slave cylinder pushrod.
Mon Jul 30, 2012 8:41 am
by garyeanderson
AChen wrote:Ongoing issues with the S4 restoration. I can't seem to get the clutch SC pushrod in place, even with the nuts turned all the way back on their threads. Not much play in the clutch fork.
Tony
Take off the C clip and slide out the the slave cylinder insert the push rod and then pull the slave back into position and then re-install the C-clip the correct way.
elan-plus-f13/clutch-slave-retaining-clip-t17341.htmlelan-f15/clutch-slave-clip-question-t14672.htmlelan-f15/clutch-slave-movement-t21335.htmlelan-f14/clutch-slave-ring-dimensions-t20000.htmlThere is a lot of info on the forum about this subject, take a look.
Gary
Mon Jul 30, 2012 9:22 am
by AChen
Thanks Gary. Obvious in hindsight.
T
