Where do I get a 10 tooth Bendix starter gear in the Uk?
Posted: Fri Jun 22, 2012 11:34 am
Just pulled the high torque starter off an s3 elan and found the 9 tooth bendix worn at the end. I've red an earlier thread about 10 teeth bendix gears and thought I would go with this. Where do you buy these from in the Uk please? Secondly is it worth insert a length of studding instead of the top bolt. Any pro's and cons. Just seems that it would be easier to replace and line up if the top connection sat on a stud.
Thanks in advance,
Thanks in advance,
