CV Question
Posted: Fri Sep 16, 2011 6:33 pm
All
My job for this weekend is to fit my new Mick Miller driveshafts to my restoration project. Something in the instructions has me a little concerned.
It says not to fit the shafts on full droop as irreparable damage could result. My chassis is on axle stands so I intend to use ratchet straps to compress the legs as much as I can. However I need to detach the A frames from the struts to give me enough clearance to get the Cv studs in. This makes the whole thing a bit unstable. Is there a better way?
Also is it ok, when the cv's are fitted to release the compression to full droop whilst I do other jobs or should I sit the back end on its wheels to put some weight on it all? What damage can be done to the CV's if fitted when in full droop?
I hope all this makes sense!
Ian.
Ian.
