No More Gearbox Oil Spills When Removing Engine.
Whenever the prop shaft is removed from the rear of the gearbox
in preparation to remove the engine/gearbox assembly from the chassis,
you know that when it's tilted, oil will pour out of the tail of the
gearbox extension.
A neat solution is to machine up a small sleeve as shown
below, which slips into the rear gearbox extension seal just like
the splined section of the prop shaft.
The capped plug will prevent gearbox oil piddling everywhere,
slide the splined prop shaft yoke out, pop the plug in, and you
can continue with the engine/gearbox removal job, tilt the
engine as steep as you like... no oil will spew out.
gearbox extension.
- ceejay
gjz30075 wrote:Nice, CJ. I'd be fearful of the weight of the oil, when tilted, pushing the plug out. Will that not happen?
Greg Z
Assuming the gearbox has been drained you are only dealing with the small volume trapped in the tail housing, still enough to make a mess on the way out. Ceejay's solution should work quite nicely. The OD of the plug could be a bit larger than that of the output yoke to assure good location by the seal.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
