gearbox dimensions
Mon Mar 21, 2011 3:30 pm
by worzel
Can anybody assist with some technical info- basically I need the distance from the front of a 4 speed box to the point where the splined section begins on the input shaft- it's to make a comparison between 2 gearboxes to see if there might be a problem with clutch actuation.
2nd question- on the later engines eg sprint- how far into the spigot bearing does the nose of the input shaft fit?
Many thanks
Re: gearbox dimensions
Mon Mar 21, 2011 3:36 pm
From the mating face to to end of the input shaft 8mm,to the start of the splines 42mm and to the bearing carrier surface 85mm.
And my needle roller bearing sits proud of the mating face by 26mm,so 18mm insertion?
Mon Mar 21, 2011 4:04 pm
Ooops,and don't forget the thickness of the spacer plate...
Mon Mar 21, 2011 7:39 pm
by worzel
Thanks for the (very) quick responses - but- (always a but) I'm slightly confused probably because of the way I worded the enquiry.
The distance I need is from the front of the gearbox casing ie the face to which the bellhousing bolts but without the nosepiece fitted to where the splines begin (the distance where the splines end might be useful too now I come to think of it).
Plus either the depth of the spigot bearing or how far the nose of the input shaft feeds into the spigot bearing.
The reason why I need them- you've probably guessed- to play around with another box to check that the clutch will work and to determine if the end of the input shaft needs to be machined.
Sorry for any (inadvertent) confusion.
Mon Mar 21, 2011 8:00 pm
Sorry,ignore the above,I was working from the bellhousing/engine face not the bellhousing/gearbox face....BUT...if you take the depth of the bellhousing as 160mm (approx) can you not get your figures from that?
Tue Mar 22, 2011 3:43 pm
by worzel
Many thanks for the info posted- useful- now have to play around with the numbers.
