Re: Gearbox swop?
Posted: Sat Nov 20, 2010 11:57 am
The normal needle rollers I use have a nylon ring at one end inside the outer case, this acts as a seal (of sorts). Position this seal to the clutch side and it helps prevent water, dirt and dust getting into the pilot bearing. As other have said its a blind hole so only need the seal at one end
