Gearbox swop?
Yep. Both the same.
Took off the flywheel today and removed the spigot / pilot bearing from the end of the crank. The little bearing was a new one and still is as new, so I'll keep it as a spare. Keeping all the 4 speed bits just now. Might part with them later.. Might not!
Started to the special holder. Easy peasy... Some pic's when its finished.
Alex....
Alex....
Alex Black.
Now Sprintless!!
Now Sprintless!!
alexblack13 wrote:Started to the special holder. Easy peasy... Some pic's when its finished.
Alex,
I'm now going from memory (dangerous, or what?), but as I 'remember' it the special holder will but-up against the end of the crank when fully inserted in the flywheel - please correct me if I'm wrong.
If this is the case, then part of the bearing will be in the crank as well as the holder.
I look forward to the pictures.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Hi all,
Just a quick question,I have read through this topic and im still a bit confused,so can some one put up a list of parts required to carry out the swap from 4 to 5 speed box,please?
I have a lotus 5 speed box,rebuilt,with bell house.
So,apart from the prop,what else do i need?
Many thanks,and sorry for being thick.....
- pauljones
Hi Paul,
Me again !!
You're also going to need the gearbox mount which is different to the four speed.
Gino
Milano
Italy
Me again !!
Gino
Milano
Italy
1964 Elan S2 Roadster
1965 Elan S2 Roadster
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1982 Lotus Esprit S3
1961 Ford Anglia
2000 Lotus Elise Motorsport-56
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Fourth Gear
Hi Paul,... All
I have had to buy...
New clutch cover. New clutch driven plate and new release bearing holder(Brian swapped me a new bearing for my old sump!). New spigot / pilot bearing (which is the same. I am just fitting a new one again).
I was told I needed a new speedo cable. Sue Miller says ''not required''.
I was told nothing about the spigot bearing holder for the 5 speed box & this def' IS required. It can be got round but IMHO better fitted. So I am making one now! This fits into the flywheel (as per Brian's post above) and allows for the shorter input shaft on the 5 speed.
CLUTCH operating lever.... I am trying to use the 4 speed lever with a mod'... easy to do I am told, but I don't as yet know what the 'mod' is. I will find out when I have the clutch bearing holder.
Brian has kindly made me a template of the exhaust mod' to clear the gearbox. I will check and do when I dry mount the box and the exhaust. Mod's will then follow as required.
I am also doing a change to the Clutch Hyd' line. I have a s/s line with banjo each end. The slave end is coming off and will be replaced with a std 3/8'' UNF Male end with lock nuts. This will be fixed onto an 'L' bracket. St'd fit Kunifer from there to the cyl', routed as well away from the heat as possible. Possibly with a little s/s shield.
Then there is the mount. Same mount, different plate! St'd plate can be modified to fit.
Clear as mud? Its no big deal so far!
Get on with it!!
Alex....
Get on with it!!
Alex....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Brian. Yes, you are correct..
Might be a week or two b4 I get some pic's up. Got the sump to paint & fit. Engine to clean down and paint block. etc...
Waiting on sump kit and clutch assy from Sue M.... Sump kit due now..Clutch assy mid dec'...Trying not to go blooming mad again..TRYING to take my time...
Keep you all posted as norm...
AB...
AB...
Alex Black.
Now Sprintless!!
Now Sprintless!!
alexblack13 wrote:I was told I needed a new speedo cable. Sue Miller says ''not required''.
Alex,
You use the short speedo cable at your peril. Only the longer cable will suit.
Take my advice based on bad experience. You must, repeat must, have the cable entering the gearbox drive unit from the LH side. This way you can have access to the drive unit by slightly increasing the hole in the body rearwards of the gearshift hole. You have to increase the hole rearwards anyway to match the gearbox.
I'm not sure if I took pictures of my car - if I did I will PM them to you.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
Hi Brian.
Thanks again man.
They don't have a longer cable. Sue says they only have one for all cars. ?? So I would have to have one made. The one on the car now looks like its long enough. Are you talking left side = Near side. Cable would then loop down over the box and curve over to the angled drive?
I know where you are coming from though. I take it you had a cable failure and had a job getting to it?
Any idea of cable total length required?
Did not know about the body mods!!!! Will I need to enlarge even with the 4 speed shift lever/gearstick used?
Bugger! I thought that was it sussed......
To deep in now to stop though.
Have a look for those pic's for us..
Alex..
Thanks again man.
Alex..
Alex Black.
Now Sprintless!!
Now Sprintless!!
I finished it! Here I go again. Had a bit of 1.1/2" BMS bar.. It was .003 too small diameter.. AArrrgh!!. Next up was a pc of 1/2" bms plate, (with a couple of dinks!) so that got used.
The bearing in the job is the one I just took out of the flywheel (everyone know how to do this easily without damaging the bearing?) The holder is pushed in flush with the rear of the flywheel. The bearing is protruding approx 3 mm which will engage a little in the crank bore.
Happy days.. Paint motor next and fit the (when painted!) sump... Still waiting on my new sump gasket kit..
Some pic's of the bearing holder etc....Hope they are helpful...
Did you find those pics Brian?
Alex..
Alex..
- Attachments
Alex Black.
Now Sprintless!!
Now Sprintless!!
Is the pivot "pin" for the clutch arm different with the 4 speed and 5 speed? It looks maybe so. I only have a 4 speed one which is too small a diameter where it fits in the 5 speed bellhousing. I want to use the 4 speed arm, does a 5 speed pivot use a wire clip like the 4 speed? over to you JPC; AB; BC!
- AussieJohn
Yes,and yes,I welded the "top" to a M? screw,adjust for required height,then locknut.
Beats me! I will have to wait n see...
?? More things that dont get mentioned. But hey..It's fun finding out
Over to you BC / JPC...
Now scratching head!! But not for long. I dont have my box yet though...
AB...
AB...
Alex Black.
Now Sprintless!!
Now Sprintless!!
alexblack13 wrote:Beats me! I will have to wait n see...
AB...
All this discussion makes me believe that the challenge to fit a concentric slave cylinder was worthwhile.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
Looks that way Brian. But no doubt it will be all very simple..Its another bit I thought I had sussed though and another aspect a few (Sue M for eg) don't know about....
We are all having some input (Batteries not included!!) and we WILL get there..
Have fun... What do you think of the needle roller holder thingymajig....?
Alex..
Alex..
Alex Black.
Now Sprintless!!
Now Sprintless!!
Dear all
I only have six (sorry 5) piccies of the relevant parts...
