Gearbox swop?
Alex
Are you going to do the gearbox?,I've done a couple (and still need to do the one in the car),they're not easy without the correct tools...
Hi all.
John, How are you? ... Good I hope...
The box is with Graham Boulton for its rebuild, which is underway I am told. I expect to have it mid - end Feb'.
I meanwhile am getting on with some of the bits n bobs that the conversion requires..
Cheers all..
Alex B....
Cheers all..
Alex B....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Hi guys.. Another two questions..
On the Sprint 4 speed box there are two spacers just under 1/2" thick which fit under the gearbox rubber mount. Between the mount and the mounting plate.
Question 1 is.... Do they still get fitted when using the 5 speed box. I will be modifying my 4 speed gearbox mounting plate and using it again with the 5 speed. Do I refit the spacers?
Question 2... What parts of the engine gets the Gray paint treatment? Just the block? Or what else? Its now cleaned (again!) and awaiting some new paint.
Just to keep yoos going....
Al' ...
Al' ...
Alex Black.
Now Sprintless!!
Now Sprintless!!
alexblack13 wrote:On the Sprint 4 speed box there are two spacers just under 1/2" thick which fit under the gearbox rubber mount. Between the mount and the mounting plate.
No spacers required. Lotus corrected that problem with the 5 speed casing.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Brill Brian... Many thanks mate.. Started to the sump yet?
All??
I took the release bearing ass'y out this am to see what was needed. Simple job to fit the 5 speed bearing to the 4 speed bearing holder. I need to make a little sleeve about 2 mm thick. Then press it on as normal. Does anyone know if its OK to use the 4 speed release bearing holder with the 5 speed bearing? Looks good to me and I think the ass'y would just clip to the release arm / lever as norm' again. Can't see any reason why not. But.....???
Al' ......
All??
Al' ......
Alex Black.
Now Sprintless!!
Now Sprintless!!
Alex
I did it the other way around,the 4-speed bearing with the 4-speed bearing holder(needed boring out a little),kept the 4 speed pressure plate..
Which arm are you using?
Just the std arm John...
Alex...
Alex...
Alex Black.
Now Sprintless!!
Now Sprintless!!
john.p.clegg wrote:I kept the 4 speed pressure plate..
That thought had occurred to me at the time I did mine but was strongly advised agaist it. I don't remember why.
Alex -- ask Graham Boulton what the reason is.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
OK. Will do. Sue Miller did not recommend either. And I am sure she was not just bumping up her sale value. She does give sound advice.
I am just trying to make sure I don't have to take it all apart again, I had ''motivation issues'' shall we say, and very nearly did not bother with it,but when I got started I just could not stop. I'm having to pace myself. Need to keep reminding myself that I have until the end of next March. No rush!! Aye right! If I had all the stuff I would be finished tomorrow night!
Anyone with an answer to my question 2 above? What parts of engine are painted with the grey?
Thanks in advance & I will keep you posted.
AB......
AB......
Alex Black.
Now Sprintless!!
Now Sprintless!!
alexblack13 wrote:Anyone with an answer to my question 2 above? What parts of engine are painted with the grey?
This link may help, Alex. Or matbe add to the confusion
elan-plus-f13/engine-colour-t20134.html
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
Thanks again Brian.
I am going to redo the block only. The rest only need a wipe..
One machine to fix tomorrow and with any luck I can get mucked into the car.. Making the pilot bearing holder and the sleeve for the release bearing. I am going to 'dry fit' the box to engine to check engagement input shaft into spigot. Then I will mount up the exhaust to get the pipes clearing the gearbox.
Wish me luck...
Alex...
Wish me luck...
Alex...
Alex Black.
Now Sprintless!!
Now Sprintless!!
Sorry to hijack the thread guys,but is the info on this swap the same as doing it on a plus 2? I too am looking at a swap over the coming months. I have a rebuilt (by Bernie at CTS) lotus 5 sp to go in place of the 4
Any advice would be greatfully apreciated
Paul
Paul
- pauljones
As far as I know it's basically the same apart for the length of the propshaft...
The input shaft and bearing
..but is it metric or imperial?
P.S. What I am getting at is,was the Ford box imperial and the Lotus/Maxi box metric and if so how much difference is the play in the spigot/spigot bearing?
P.P.S/ maybe I should shift this to the gearbox swap thread..
john.p.clegg wrote:The input shaft and bearing
John,
The spigot diameter on the Ford 4 speed and the Lotus 5 speed is 15mm.
The INA standard bearing is designated as 21x15mm (nominal O/D & I/D)
Ford in Europe were not averse to using standard metric bearings in the dark pre 1970 imperial times.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
