T5 transmission for +2?
PostPost by: forfenderjazz » Sun Sep 25, 2005 6:25 pm
TomR, how happy are you with the ratios? I am glad to hear that someone else has done this. Mustang parts are plentiful and low priced, so the idea of using the all alluminum Mustang box is exciting. What are you using for a shifter? Did your shifter end up in a good position? Thanks, Roy
forfenderjazz
First Gear
First Gear
PostPost by: rgh0 » Mon Sep 26, 2005 10:33 am
Thor
I used normal plain washers that fitted over the lever from the top with the knob removed. I ended up using a stack about 12mm high below the circlip on the change lever shaft.
Previous
