CV Driveshafts
'Dogrings'. Weird name and I dont see the connection with CV driveshafts.
I curious the 'forward inertia that drives the wheel and axle forward' that is mentioned on their website?
One or two other points look a bit suspect to, a suggestions to increasing the track 0.15", how would one do that on an Elan, make new rear 'A' links? (and then have to modify the Lotocone chassis mount. I can see lots of owners rushing out to do that! Also whilst conversant with most USA names for parts of cars, what 'headers' are near the rear axle?
Ian
Ian
Elanman99 - Fourth Gear
The company that sells the the donut savers specializes in parts for Hewland racing transmissions. "Dog rings" are explained pretty well here. http://www.circletrack.com/techarticles ... ewall.html
The header comment would come into play for a mid-engined car with the headers running just above the rear drive train. They're open wheel focused while we're elan focused.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
robertverhey wrote:They're back
http://www.ebay.com.au/itm/FIAT-X1-9-X1 ... 27cd13f801
Personally I don't see how people expect to sell things on ebay with such an abrasive attitude....but each to their own....
Not only abrasive, but evasive too!
I asked Tom via the 'ask the seller a question', I said that he had described the shafts as 300mm long but I wanted to know the extended and compressed length?
His reply, 'They are 300mm long'!!!!
In for a penny, in for a pound, so I have asked again but did not address him as Tom this time (his eBay name is tombraider) Silly me thought he was Mr Braider.
Meanwhile these are the same but in much better condition, 'Remanufactured'
http://www.ebay.co.uk/itm/260668418557? ... 1423.l2649
Ian
Elanman99 wrote:'Dogrings'. Weird name and I dont see the connection with CV driveshafts.
Ian
I think they just mean that if the inner doughnut comes apart while running, the side-shaft may flail about with the total energy of the forward motion of the car available to it, and if it should catch on anything the force will be great enough to break or bend lots of things.
It might be possible to compensate that 0.15 inches by fitting one or both doughnuts through the 'wrong' holes. Normally we fit them with the raised ends against the side-shaft or diff shaft. Fitting in the depressed holes would make the overall length a little shorter. Not sure if that would cause other problems.
billwill wrote:It might be possible to compensate that 0.15 inches by fitting one or both doughnuts through the 'wrong' holes. Normally we fit them with the raised ends against the side-shaft or diff shaft. Fitting in the depressed holes would make the overall length a little shorter. Not sure if that would cause other problems.
I've seen the result of fitting to the 'depressed' holes. The 'spiders' of the various shafts cut into the donut. That I would think would lead to premature failure.
How did we get here from CVs......?
Roy
'65 S2
'65 S2
elj221c - Fourth Gear
