tonyabacus wrote:Does anyone know or have access to some elan shafts to verify their length with donuts attached?
Tony
Hi Tony
5 weeks ago I could have given you a better answer as I had a set of new donuts, They were installed on the "Sow's Ear Chassis" back on September 24th, your timing is off and this is a "best guess" with some used donuts. The donuts have a "high boss" and my guess is that it "may be" about an eighth of an inch per donut.
The width of the donut interleaves that the bolt passes though measured up at 1.726
The half shaft itself measures 8.875 inches
what does it all mean? I don't have a clue. added up with some guessing and a "slop factor" included might be 12.875 or there abouts but my guess is this info is not anything that will be of real use in trying to determine the length of a CV half shaft. I believe that if you wanted to get it right you would need to set up the rear suspension without a spring and install your rear rotor with the adapter plates and "then" take a measurement at it shortest and longest then add some for a safety factor. not doing this would probably get you something that may work but might not work. There is probably better info on this forum that is of real use. Others have done the job and they have given out the info that they have used. Now that there are about 2000 topics on CV's it makes it more difficult to find. The more questions there are, and the more answers that are given, the less use this forum becomes. Then you just need to pick the answer that you want to hear
Gary
