twincamman wrote:well the tranny on the super 7 is about toast after a hundred and ninety thousand miles -a rebuilt is 1500 US and the parts are 800 d-so any of you z tech hot rodders have a suggestion for a 5 speed ford tranny that bolts right on a 4 bolt crank twin cam bell housing and block and puts the shifter in the correct position????ed
Ed,
there's been a fair amount of dialogue about 5 & 6 speed g/boxes recently.
There are two main problems that you will have:
1.
Sourcing a suitable box in your part of the World.
There's the Voigt conversion or the European Ford MT75.
Both will bolt straight on to the Twinc & Spyder bits can put the MT75 gear lever in the right position.
(Clutch operation will also need to be sorted out)
2.
In the 7 the amount of available space is the biggest problem.
I know that the MT75 box is a bit fatter than the Elan box.
That may cause it to intrude into the footwell space which is already very limited in a 7
I suspect that a rebuild of yor present box will be the best alternative (& don't hammer it so hard in future
