new pinion gear for hi torque starter
Hi Guys,
Just managed to chip a tooth on my new hi torque pre-engaged starter.
(don't ask!)
http://www.autoelectricsupplies.co.uk/product/793
Anyone know where I can get a new pinion and/or someone to fit it!
(don't ask!)
1972 +2S130
tdafforn - Coveted Fifth Gear
Come on Tim,tell us the story,,,,
Tim,
Contact Luke at http://lukemotorsport.co.uk/lukemotorsportua.html
He sells starter spares - even the correct 9 tooth pinion varieties for the Twinc. I guess you will need to verfiy that the the base starter you have is the same or compatible as the ones he sells.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Ok Ok...
Was playing around with the cranking ignition advance on the megasquirt setup I have on the lotus..
ending up inducing a backfire mid-crank (while parked up in a multistorey car park). the backfire chipped a tooth clean off..
had to get a push start to get back home (hoping I didn't stall on the way!)
1972 +2S130
Users browsing this forum: Stagmatt and 28 guests
