Spigot Bearing
PostPost by: saildrive2001 » Fri Mar 13, 2009 5:23 pm
Can anyone tell me how to remove the needle roller spigot bearing from the end of the crankshaft without resorting to destroying it. I have a new one but I would like to remove the old one without resorting to brutal means.
Keith Marshall
saildrive2001
PostPost by: john.p.clegg » Fri Mar 13, 2009 5:39 pm
Find a piece of bar the same size as the spigot,fill the bearing hole with grease,"whack" the bar into the bearing,the resultant pressure should force the old bearing out....
John :wink:
PostPost by: gjz30075 » Fri Mar 13, 2009 5:41 pm
This tool: http://search.harborfreight.com/cpisear ... &Submit=Go is your best bet. AutoZone (if you have one in your area) will rent one to you.
Greg Z
'72 sprint
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: elansprint » Fri Mar 13, 2009 6:26 pm
I'm with john the grease method has always worked for me
Ian
elansprint
PostPost by: GrUmPyBoDgEr » Sat Mar 14, 2009 10:29 am
john.p.clegg wrote:Find a piece of bar the same size as the spigot,fill the bearing hole with grease,"whack" the bar into the bearing,the resultant pressure should force the old bearing out....
John :wink:
Can I assume that the spigot on the end of the clutch alignment tool would do the jab as well then?
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: john.p.clegg » Sat Mar 14, 2009 10:37 am
Yes,that should be no problem as long as you don't mind maybe "peening" over the end of the tool by not "whacking " it straight with your hammer.
A cloth covering it may prevent you being sprayed with grease...
John :wink:
PostPost by: Frank Howard » Sat Mar 14, 2009 2:29 pm
This method works great on a standard bronze bearing. I did not have such good luck doing it this way with a needle bearing because rather than pressurize the rear of the bearing, the grease would escape through the needle rollers. Let us know if it worked for you.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: GrUmPyBoDgEr » Sat Mar 14, 2009 7:05 pm
You hit it too slowly Frank.
Hit it quick & duck :D
GrUmPyBoDgEr
PostPost by: saildrive2001 » Sun Mar 15, 2009 3:50 am
Thanks for the advice, I need to find a piece of rod the correct size. I can't use the alignment tool from Bean's as it is plastic also they sent me the wrong bearing [bronze but also the wrong size]. Do any of you have a bearing # for the needle roller bearing?
Keith Marshall
saildrive2001
PostPost by: saildrive2001 » Mon Mar 16, 2009 7:49 pm
I got the bearing out using the grease method, now all I have to do is find a replacement.
Thanks again to the members of this group for your invaluable help.
Keith Marshall
saildrive2001
