Refitting rear hubs, what to put on shaft...can't find post.
Hi there
I have just had my rear hubs machined true, (although the machine shop left the drive pegs out!) and I remember reading a post that mentioned something to put on the shafts that stopped any fretting. Otherwise what should I use? Copper grease?
Also if I tap the drive pegs back in with a socket the other side of the flange (to spread the load) do you think that would be OK? I do not want to distort them. I will heat the hole with a blowtorch first and maybe freeze the pegs.
Many thanks
Many thanks
berni29 - Fourth Gear
Berni,
Yep use locktite - Stud N' Bearing Fit. It's in a red tube. Good stuff.
Hamish.
Hamish.
Hamish Coutts - Fourth Gear
