5 speed conversion
I completed a 5 speed conversion for my Plus 2 using an alpha box last year, final drive is .78 with a 3.55 rear cruises very comfortably. We made a 1" aluminum adaptor to mate the original lotus bell housing to the front of the ALpha box. Fit in the car was very easy, kept the originial shifter location, very little fitting problems. Biggest hassel was the spreedo conversion but that looks to be solved as well. Have about 500 miles with no problems. Any one wants to see the car in Massachusetts or learn more, drop me a note.
- crannyr
Hi Rick
Good to see someone local doing all the engineering, I would like to take a look some time. Its been a while (92 or 93) since I have been out your way. I stopped at your shop and met you an Noel Poduje. Thanks for the info
Gary
Gary
Rick,
Count me in for a visit as well. Gary seems to have been a more recent visitor, I don't think I have been out your way for at least 15 years. I have not seen your +2 since the first LOG in Connecticut when you were there with your race car as well. I seem to recall your +2 is very close to mine in terms of chassis number. I have been thinking about going the way of the Alan Voights Ford T9 conversion. I am very interested in all the details, ratios of each gear etc.
Russ
Russ
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Gear box was out of a Giulia, ratios: 3.304, 1.988, 1.355, 1.000, and .791. Speedo converion used the stock right angle drive with a new retaining nut (cut for meteric threads) and a ratio adaptor spliced into the speedo cable from APT(http://www.gaugeguys.com/). Also had a custom driveshaft made. All th original clutch components can be used save the disk which is a different spline but very available. For my conversion I close to convert to a annular slave cylinder(Dave Bean amoung others) while it was easy to design a mount on the adaptor plate. Had some modificatios made to the gear box rear housing for clearance and mounting but nothing major and only needed minor welding for a tranny mount.
- crannyr
Russ and Gary. You guys are more than welcome to come over and take a look. Car is at my home in Grafton and on stands for it winter service and tweeks. At the same time you can take a look at Danny's Plus 2 with the 1850cc FI and spyder conversions. Weekends are best and everything is unheated so pick a warn day. Call me at 508 839 3418.
- crannyr
Hi Rick
I will talk with Russ and a few other interested parties to establish a good weekend date, that way you won't have to show it off to many times.
Gary
Gary
I found this page on Alfa Giulia gearbox with photos of a strip down, not sure this is the one Rick is refering to but the shift is in the right place. the donut on the back has me worried though.
Gary
http://www.alfaworkshop.co.uk/alfa_giul ... trip.shtml
Gary
If you have done a CV joint replacement the donut might be good to give you some give in the drive train. Many modern cars have rubber discs in their drive shafts.
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
garyeanderson wrote:Hi Rick
Gary
Gary,
Please sign me up as an "interested party." Rick told me about this conversion while we were discussing the 1700cc engine.
Andy
RotoFlexible - Fourth Gear
Hi Andy
Bill Gavin is interested too. sounds like Rick is in for a flock of Lotus nuts to show up and paw all over his Plus 2. I am interested in the F.I. 1850 engine in Danny's car too.
Gary
Gary
photos will not attach, tranny installation was easier. Anyone wants photos email me at [email protected]
- crannyr
Hi Rick
Send them to me at [email protected] and I'll get them up here.
Too cold today to do much else anyway.
Gary
Gary
Last edited by garyeanderson on Mon Feb 19, 2007 11:39 pm, edited 1 time in total.
