Transmission Fluid?
I'm gonna flush my 4-speed gearbox and refill it. What's the current recommendation on filling it up? Just regular transmission fluid? I've seen banter in the past about what people switched to in the 80's, 90's, etc...
Thanks!
Thanks!
1970 Lotus Elan +2, 1991 Lotus Elan, 2006 Lotus Elise, all for sale.
Hegg - Second Gear
Hi Hegg
I'm not going to be much help because I am going to do the same with my 5 speed and I do not know what the best oil is. I was hoping that there would be a synthetic oil available that would cut down on wear.
Anyone tried synthetic in a gearbox?
Ta
Berni
Ta
Berni
berni29 - Fourth Gear
I have Redline MT-90 in my tranny. Shift engagement is quite nice.
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
Any of the synthetic gear lubes are good and Redline is best. Redline "MTL" is the correct equivalent to the original viscosity specification. The thicker MT-90 will work OK but the change will not be as good as with the MTL.
I have MTL in my 4 speed Elan and it makes the change even slicker than normal. In my 5 speed plus 2 it makes the normally slow change action much better and helps the weak syncros keep up.
I still use 80 weight hypoed-----ain't nuthin slipperier or better for the job --in my humble opinion --and with 160 000 miles on the super 7 tranny i feel it bears out my thinking --- ed <_<
Yes good old mineral EP Smelly!
Use the GL4 rated stuff only. The newer GL5 stuff can attack the brass bits in vintage gearboxes.
- type26owner
140W dino or ATF (mineral only). All are GL4 rated and okay to use in a manual gearbox. They differ in viscosity from the 80W stuff. 140W is thicker. ATF is thinner. Share the same GL4 lubrication properties though.
- type26owner
pretend your leading the race and d d everywhere ed
