Ditching the donuts
PostPosted: Wed Jun 14, 2006 9:22 am
by Robbie693
I'm thinking about changing my driveshafts to the UJ/sliding spline type.
What's the difference between the Tony Thompson ones and the types sold by Paul Matty and Sue Miller? All seem to be the same price (380.00 quid).
Do they ever do deals on these at shows?
Also, the original gallery semms to have gone. I remember someone posted pictures of this set-up there, can anyone put some new ones up in the new gallery pleeease?
Robbie
Re: Ditching the donuts
PostPosted: Wed Jun 14, 2006 11:37 am
by nebogipfel
Robbie, if you check the archive this subject has been discussed many times.
Don't know what the TT ones are like but I can vouch for the SM ones as being a good bit of kit. I'm pretty sure PM buys shafts from Susan Miller.
PostPosted: Wed Jun 14, 2006 11:55 am
by GrUmPyBoDgEr
The SM driveshafts use 2 constant velocity joints & are probably the best alternative for road car conversions. The original TTR shafts use 2 universal joints & a sliding spline; they are very nicely engineered & are a solution for the racers because these are acceptable to the FIA as being equivalent to to the original 26R spec. parts. I think he can also supply drive shafts with 2 CV joints, check with his website.
Another variant is available from Spyder; these use a donut for the inner joint & a CV joint on the outer end, a sort of compromise to the arguments rubber cushioning or not.
John.
PostPosted: Wed Jun 14, 2006 12:49 pm
by Robbie693
Ah, I see thanks
I thought Sue Miller did the UJ type.
Paul Matty lists "# Driveshaft kit. Glide coated / splined" so I wondered who made those
PostPosted: Wed Jun 14, 2006 1:41 pm
by steveww
AFAIK Paul Matty get their competition bits from Tony Thompson including the driveshafts. I have installed the TTR UJ/spline driveshafts on my S4 and I am very pleased with them.
PostPosted: Wed Jun 14, 2006 3:54 pm
by Robbie693
Cool, thanks for that. It'll save me the postage!
PostPosted: Thu Jun 22, 2006 2:58 am
by twincamman
here a pic of mine ---ed
PostPosted: Thu Jun 22, 2006 9:12 am
by Robbie693
Thanks Ed, are those are the CV joint type?
PostPosted: Thu Jun 22, 2006 12:09 pm
by twincamman
sliding spline with universals at each end --very similar to triumph-----ed
PostPosted: Thu Jun 22, 2006 12:30 pm
by Hamish Coutts
Robbie,
I've got sliding spline type with universals at each end (TTR). Fab, built like brick shithouse doors (er, robust) and dead easy to fit, once you've got the original 'shafts off, that is.
Hamish.
PostPosted: Thu Jun 22, 2006 2:19 pm
by thor
And none of that boing - boing elastic band sensation :D ? I'm still worried about the driveline wear though. But at the short distances and low speeds I usually do that won't really be an issue me thinks..
PostPosted: Thu Jun 22, 2006 2:30 pm
by Robbie693
I like the sound of that Hamish (the dead easy to fit bit), am I correct in thinking that the 'failsafe' pins (spigots) that protrude from the inboard and outboard shafts need to be removed? How easy is this?
Do you have any pics of your set-up?
PostPosted: Thu Jun 22, 2006 4:50 pm
by stuartgb100
How easy to remove the fail-safe?
Dead easy. Just did it an hour or so ago.
Simply cut it off with an angle grinder, then trim it up with a grinding wheel until it is no longer proud of the spiders.
Stuart.
(Inboard and outboard cv joints from Susan Miller).
PostPosted: Thu Jun 22, 2006 7:54 pm
by alaric
I fitted the CV joint version from Sue Miller. They were a very tight fit to the original diff and hub flanges. I think most people don't have a problem fitting them but when I phoned Sue she did say that PM had found this once before. My car has the fail safe shafts and I ground off the pins with an angle grinder - no problem. Unfortunately I tapped one of the shafts into place on a hub, then trying to remove it again bent the hub flange - I had to replace the outboard hub shaft. To fit them I used an adustable reamer to open up the holes on the diff and hub flanges. Very neat now. It's possible that the flange distorted when I ground off the pin, as it did get quite hot.
If you try to fit new shafts, Sue's or others, and the studs won't pop onto the flanges with a snug fit, but are tight, then stop and ream out the holes. Otherwise it was easy to do the conversion.
Sean.
PostPosted: Thu Jun 22, 2006 11:02 pm
by Hamish Coutts
Robbie,
As Stuart says just remove the failsafe pins with an angle grinder and the rest is easy (TTR in my case). I didn't find that anything overheated.
Hamish.
