S2 Trunk Hinge nut size
Can anyone tell me the correct size for the nuts that hold the trunk lid to the hinge on an S2? The part book shows LUCN040F which I think would 1/4 -28 but from memory they didn’t seem that large, I remember #10-28 . .
Thank you,
Ian
Thank you,
Ian
- Ianashdown
Ian, my S2 has ¼ unc nuts and is listed the same in the Lotus fastener list.
Pretty sure my pre-airflow coupe, which still uses the same hinges as a S1-2 is attached w/ 1/4-28 UNF hardware. I can't verify that today since the coupe is 900 miles away.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Elan45 wrote:Pretty sure my pre-airflow coupe, which still uses the same hinges as a S1-2 is attached w/ 1/4-28 UNF hardware.Roger
Roger,
You got me thinking so took one nut off and mine are definatly 1/4UNC anthough not Nylocs as stated in the Manual.
Not sure on the stud thread but the female holes on my +2 hinges are 1/4unf (tpi). Can't see why they would be different on an elan.
- mbell
On a +2 the hinges are the same as a S4 Elan. But S1 and S2 hinges are i think different.
- alan.barker
Well, I think we’ve established that they are 1/4”! I think I’ll take both UNC & UNF!
Ian
Ian
- Ianashdown
My S1 are UNC and appear to have been some kind of a self tapper. All studs have flutes like a tap and are very hard. One was broken and a near impossibility to remove. The others would very obviously have broken if I had kept trying to remove them. Planned to remove for plating and replace with better studs but gave up on that and after great difficulty had to heli-coil the broken one.
Kurt
26/3754
Kurt
26/3754
- nomad
Users browsing this forum: huggy59 and 19 guests
