S1 Dash Q.
PostPost by: Brock » Thu Mar 17, 2022 1:34 am
Hi All,
Search results didn't satisfy -- and besides, new threads keep this place alive...
Did any S1 have a one-piece dashboard? Specifically 3370... I'm thinking my car should be two-piece, but it ain't.
Thanks.
1964 Elan 1600 #3370
Brock
PostPost by: elancoupe » Thu Mar 17, 2022 2:12 am
#3644 has a typical S1 dash - with cubby hole
elancoupe
PostPost by: GLB » Thu Mar 17, 2022 4:24 pm
I have seen pictures of late S 1's with one piece dash but no idea of the unit number. Gary
GLB
PostPost by: nomad » Thu Mar 17, 2022 6:39 pm
I think towards the end of the S1 production there was considerable overlap on several things but I would bet yours originally did have the fiberglass box.
Kurt
nomad
PostPost by: Brock » Thu Mar 17, 2022 7:30 pm
Thanks guys. ... I am now even less constrained by originality with this car. I can dig that. Takes the pressure off.
This repro S2 dash has given up in the heat. Now an internal debate about veneer. Teak: Can't find it. Mahogany: I want teak. Walnut: a bit too Jaguar or +2...
Brock
PostPost by: GLB » Thu Mar 17, 2022 8:48 pm
I just searched teak veneer on Amazon and there are several choices. I used paper backed teak veneer on mine, attached with West System epoxy. came out great and easy to do. Veneer on plastic sheet, ply dash and lots of weight on top. Paper backing makes it easy. I did solid unbacked walnut burl on my +2. Had to use a vacuum bag. Came out good but lots more work and supplies. Probably could have bought one for same cost but I learned a new skill. Gary
GLB
PostPost by: trw99 » Fri Mar 18, 2022 9:19 am
The full width veneer dash with lockable glovebox replaced the part width oiled teak unit officially with the introduction of the Series 2 from Unit No 3901 in Nov 64.
However, a glove box door had been available as an option for sometime on the 1600 beforehand. In addition, we know about the Series 1 1/2 which saw some of the S2 changes introduced onto the production line before the 1600 run out.
PostPost by: Brock » Fri Mar 18, 2022 2:04 pm
Gary... Amazon.com has lots of choice, yes.... Amazon.ca does not. Ve vill eat ze bugs in Soviet Canuckastan.
And Tim... You're the Purist I was looking for. There's no such thing as an S1.
Thanks.
Brock
