Is my rear parcel shelf normal?
PostPost by: berni29 » Thu Nov 11, 2021 10:57 pm
I have never noticed this with Plus 2's before but my rear parcel shelf does not seem normal. Mine is fiberglass and integrated with the body. In that all the pictures I have seen on the internet it's a removable trimmed panel.
Pictures below.
Many thanks
Berni
Screen Shot 2021-11-11 at 23.10.53.png and
I thought they looked more like this.........
IMG_0622.JPG and
My one........
berni29
PostPost by: Foxie » Thu Nov 11, 2021 11:31 pm
Hi Berni,
It may be of interest, that in order to make my 1970 Plus 2S meet FIA /Motorsport Ireland regulations for competition I had to fit an aluminium firewall between the passenger cabin and the fuel tank, using pop-rivets and fibreglass.
I refitted the original parcel shelf trim back over the aluminium sheeting. (Less the radio speakers ! )
Does your fibreglass arrangement seal off the fuel tank ?
68 Elan +2, 70 Elan +2s
PostPost by: 2cams70 » Fri Nov 12, 2021 9:19 am
Foxie wrote:It may be of interest, that in order to make my 1970 Plus 2S meet FIA /Motorsport Ireland regulations for competition I had to fit an aluminium firewall between the passenger cabin and the fuel tank, using pop-rivets and fibreglass.
Yes suspect that is the reason. Around this time the Ford Pinto with it's exploding fuel tank was causing issues. No doubt the FMVSS regulators at the time saw fit to introduce regulations to isolate the boot area and fuel tank from the passenger compartment.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: berni29 » Fri Nov 12, 2021 9:51 am
Hi Guys
It looks like we have the winner! Yes the car used to be raced. Thank you very much. This answer helps me out in a couple of different ways. I was using the holes in the shelf as a data point for some measurements, and clearly they are not going to be accurate as the shelf is not part of the body structure as such.
Many thanks again
Berni
berni29
PostPost by: alanr » Fri Nov 12, 2021 11:17 am
I have been following your very brave saga with interest.....
There is no fibreglass structure in the centre at the rear of a +2. The rear parcel shelf above the tank in my +2 is just vynil covered hardboard!
The pics below may help you visualise how the body structure is on a standard car:-
See here my pics during changing the fuel tank which may help. The first pic is after removing the fuel tank and afterwards with having done the fuel tank pipe mod . You can see the the turret structures of the body are just at the sides with a bolted centre brace between the two turrets. So any measurement you may be proposing to do i would suggest be from the turret tops at the sides or underneath the tank on the floor of the body.
022.jpg and
2 Breather Pipe Mod.jpg and
Hope this helps.
'71 +2 S130/ 5speed Type9.
PostPost by: Bud English » Fri Nov 12, 2021 4:50 pm
Normal is over rated! :wink:
Bud
1970 +2S Fed 0053N
Bud English
PostPost by: berni29 » Fri Nov 12, 2021 6:32 pm
Hi Alan,
Thank you for the information, and also very nice work on the tank!
Berni
berni29
