Seat runner rear fixing S4
PostPost by: Mileso » Sat Aug 21, 2021 1:58 pm
Just fitted new sound/heat proofing felt and carpet and, correctly, fitted new s/s runners over the carpet.
My query is how do you bolt the rear 'inner' points. No bobbin (none on other fixing points either so nut/bolt/washers employed), just a hole through floor for bolt/nut and washer but the body is sitting on the chassis so no access to put a nut in from u/s.
Not overly worried as seat keeps them down when in place, but would like it to be right.
Solutions/thoughts welcome - glass/glue a thin nut to topside - or is there some expander thing that may suit - large pop rivet?
Mileso
PostPost by: 1owner69Elan » Sat Aug 21, 2021 3:59 pm
I will check later today but if I recall correctly the rear inside seat runner bolt (or stud) goes through a hole in the frame.
As original on my car. Body never removed.
Was your frame replaced?
You may need to drill a hole from the top through the frame. Not an owner bodge. As done by the factory on my 1969 S4 Federal. But, I will recheck and post a photo.
BTW. Are you using non tip runners?
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: 2tmike » Sat Aug 21, 2021 6:19 pm
Bolts through the chassis flange on mine
Elan S4
Elan Plus 2 JPS
MR2turbo
2tmike
PostPost by: Mileso » Sat Aug 21, 2021 6:36 pm
Cheers both. Will consider drilling.
Yes it has had a new chassis in its life and mine are not anti tip so basic angle s/s.
Mileso
PostPost by: 1owner69Elan » Sat Aug 21, 2021 6:42 pm
Here is a picture of the rear inside runner studs through the frame.
IMG_7761.jpeg and
I have thread protectors over the threads, as shown. Mainly to protect my head when under the car.
'69 Elan S4 SE
Street 181 BHP
Original owner
