Plus 2 Window frame assembly
PostPost by: NYK » Thu Aug 05, 2021 5:46 pm
Can anyone confirm that the felt strip wipes the outside of the window glass, item 33.
E96FA653-29FC-4CE1-82E8-D0F1CF6930BA.jpeg and
NYK
PostPost by: h20hamelan » Thu Aug 05, 2021 7:17 pm
I too am disassembling +2 doors
Would like clarity too!
From how I understand, the front 1/4 window has its own seal surrounding the inside. This piece continues along the entire length of the window frame to door encompassing the front 1/4's
Love your Mother
Earth
PostPost by: mbell » Thu Aug 05, 2021 7:39 pm
There is a rubber seal that contact the glass on the outside, isn't a lower felt strip on my car. Hard to see the detail from the diagram.
The front 1/4 is sealed in with some kind of putty on on my car.
PostPost by: NYK » Thu Aug 05, 2021 7:50 pm
Yes, bought all the seals and felt from Sue Miller but can’t 100% work out exactly what goes where
NYK
PostPost by: h20hamelan » Thu Aug 05, 2021 7:53 pm
felt on both my +2's below the rubber, probably as a damper/cushion
Love your Mother
Earth
PostPost by: NYK » Thu Aug 05, 2021 8:31 pm
h20hamelan wrote:felt on both my +2's below the rubber, probably as a damper/cushion
NYK
PostPost by: Bigbaldybloke » Wed Aug 18, 2021 3:37 pm
Have you solved this, I’m in the same position
PostPost by: NYK » Wed Aug 18, 2021 3:45 pm
Bigbaldybloke wrote:Have you solved this, I’m in the same position
Yes, I’ve now got the window and quarter light in the frame and frame in the door. Have yet to do the next tricky bit which is is outer rubber seal and chrome strip. Quarter light was a bit of a swine.
NYK
