Plus 2 mystery holes ?
This car came to me in a disassembled state and as such is presenting some mysteries. Can anyone identify the pair of holes in the door to roof opening ? I see the countersunk holes are for the headliner bow retainers but these two plain holes have me baffled. There is a matching pair on the other side.
Thanks in advance !
Thanks in advance !
Former owner: 26/4100
Current owner: 14/1157
- klfulop
is the photo inside of the door sill, or inside of the cabin?
Love your Mother
Earth
Love your Mother
Earth
h20hamelan wrote:is the photo inside of the door sill, or inside of the cabin?
Sorry. The photo is from the outside of the car looking into the top of the door opening up towards the roof. Additionally the photo is rotated 90 degrees (just to make it more confusing).
It seems like we have identified the pair of holes as rivet holes for securing the courtesy light housings. I would still like to know what the third rivet on the housing goes to.
- klfulop
The ground wire is riveted there.
The metal box is mounted on the upper inside of the door frame under the headliner.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Bud English wrote:The ground wire is riveted there.
Wow ! Riveted ground wire ! Crazy. But that would explain it.
Thank you gentlemen !
- klfulop
klfulop wrote:Bud English wrote:The ground wire is riveted there.
Riveted to what? - hard to tell from the photos. If the ground wire is riveted to the (fiberglass) body, won't be doing much grounding.
- Slowtus
Assuming the meaning is the Purple/White wire riveted to the box or light?
The Purple/White forms the courtesy light ground loop, which includes one contact of the door switches and the dash switch in a loop. The lights typically come on if any of the multiple switches are closed to their Black ground (located on the other contact of each individual switch).
The courtesy light above the rear view mirror also has a multi position switch that allows only the single light to come on by grounding to it’s own Black.
Interesting as this courtesy light location is for the later cars; our Federal cars have the lights located on the C pillar panel.
HTH. Apologies if this is already obvious, but still beastly cold here! . Might help someone in the future searching the archives I guess.
Stu
1969 Plus 2 Federal LHD
