Fitting S3 dash
Posted: Mon Nov 23, 2020 5:09 pm
Good evening,
I am in the process of refitting the original dash into my S3. It was removed in 1980 by the PO. All the screws line up and it is hard against the lower mounting bracket. The outer two screws will also pull in when tightened (the dash is a little warped). However, it is still about inch clear of the bobbins at the the top two screws above the bonnet release handles. Is this correct? Comparing to pictures on this site, it looks correctly recessed in the crashpad but I am still worried, especially as the dash is a structural part of the body. How much should the dash be inset at the centre from the crashpad?
Another question. Sue Miller provided fixing bolts of different lengths. I assume the two longer ones go top center, maybe because the shorter ones would not reach the fixing bobbins.
As suggested on this site, the heater is hard back against the bulkhead with minimum insulation under.
Thanks in advance for any suggestions.
Cheers.
Cheers.
