Curved Panel Behind seats - S4 DHC
Does anyone have any suggestions for a suitable material to make up a new panel at the rear of the cockpit in an S4?
I am re-carpeting my 1970 S4 DHC and will have to replace said panel as mine has disintegrated. It's the one that's curved and bolts to the edge of the hood tray at the top and straddles the transmission tunnel at the bottom. I have attached a photo 'borrowed' from a previous posting - thanks & acknowledgements to Terry Posma.
I was originally thinking of ⅛" thick Masonite (wetted on the back surface) but I know that there are some thin, black fiber board products out there that would be much easier to bend into the required curves, but have no idea what they're called or where to source them.
'60 Elite type 14
'67 Seven Climax
'70 Elan S4 DHC
'70 Elan +2
'72 Elan Sprint Coupe
'73 Europa Special
'83 Esprit Turbo
'60 Elite type 14
'67 Seven Climax
'70 Elan S4 DHC
'70 Elan +2
'73 Europa Special
'83 Esprit Turbo
- Attachments
- Cockpit%20backboard%20008.jpg (88.41 KiB) Viewed 812 times
- velo5338
That photo is my car.
I used 3mm foamed PVC sheet sold in the UK as Palight, it's easy to cut and can be formed and bent with a little heat from a hot air gun.
S4 DHC
S4 DHC
- oldelanman
I bought some black millboard online. It seems very similar to the original. However, the pieces are not long enough in one dimension. They reach down to the tunnel but not much lower. I don't have time to find the link at this moment but let me know if you want it.
We are supposed to be having fun, are we not?
- USA64
Thanks all.
Just checked out the Palight foam PVC board. It looks ideal - and is available in black at the local Home Depot just around the corner!
Great lead - thanks oldelanman., and I hope you didn't mind me appropriating your photo.
I'll report back.
I'll report back.
- velo5338
Hi Mike,
I used a sheet of 3mm polycarbonate. Did not require heat to bend into shape. Glued carpet directly to it to match the original.
Colin.
quote="velo5338"]Thanks all.
I'll report back.
Mike[/quote]
Colin.
I'll report back.
Mike[/quote]
'68 S4 DHC
- fatboyoz
Just to clarify my earlier post .. like thin plywood, millboard, hardboard etc the foamed PVC sheet is flexible enough to be bent round simple curves without heating but it has the advantage that it will retain the final shape if heated gently.
By applying more heat the material can be bent and formed into quite complex shapes.
S4 DHC
S4 DHC
- oldelanman
velo5338 wrote:Hey Roger, 'oldelanman',
Is that a battery disconnect switch sticking through the centre of the back panel, just above the transmission tunnel?
Hi Mike, Yes it is.
S4 DHC
S4 DHC
- oldelanman
Cool - and very sensible.
The Elan S4 I just bought had a battery disconnect switch mounted in the dash in the place of the cigar lighter. Very accessible -but very ugly.
I'm installing a new dash so will relocate the BDS to somewhere at the rear of the cockpit. It was on my mind when thinking about the rear panel, so I was pleased to notice yours.
My battery had been relocated to the centre, immediately behind that rear panel. I might just leave it there. Can't think of any good reason not to.
Thanks again for your help with this,
- velo5338
Users browsing this forum: Richardsona39 and 40 guests
