Lotus Elan headlight pods stay up while parked
Appreciate anyone’s advice if the headlight pods stay up or in closed position when the engine is off and car is parked. My comes up after a while (about 15 minutes) and I wonder if this is normal. If not, how do we keep them closed?
Thank you
Tony
1969 Lotus Elan
Thank you
Tony
1969 Lotus Elan
- Soonteo
You car has a Vacuum leak.
The first easy check is the "T" Vacuum take off. This is front middle of Chassis Cross Member connected to Vacuum Tubes. It often goes rotten.
- alan.barker
Before looking for faults, it depends on whether your car is configured to be “failsafe” or not.
What is the model type and year ?
'72 Sprint
'72 Sprint
- richardcox_lotus
I think he confirmed they are Failsafe, "they come up after about 15 mins" = Failsafe with a leak
- alan.barker
TBG wrote:Mine are not "Fail Safe" but if I leave them up they come down after a few days. Not a problem. They stay up when they are needed under all conditions.
You have obviously never experienced driving on a dark and very rainy night on a busy M20, a 40 ton artic stuck up your a**e, with all lights blazing, and every time you try to give the Lotus a little more throttle, the headlamps sink a little lower..........
Installing my Spyder headlight kit at the moment !
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Foxie wrote:TBG wrote:Mine are not "Fail Safe" but if I leave them up they come down after a few days. Not a problem. They stay up when they are needed under all conditions.
You have obviously have never experienced driving on a dark and very rainy night on a busy M20, with a 40 ton artic stuck up your a**e, with all lights blazing, and every time you try to give the Lotus a little more throttle, the headlamps sink a little lower..........
Been there and had that, except it was on the M40.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
"You have obviously never experienced driving on a dark and very rainy night on a busy M20, a 40 ton artic stuck up your a**e, with all lights blazing, and every time you try to give the Lotus a little more throttle, the headlamps sink a little lower.........."
If your headlights sink low when you press the throttle your car definitely needs some TLC. Throwing money at Spyder is one way, but proper care and maintenance is another. Never had a problem in well over 200k miles.
- TBG
A simple mod with a bicycle innertube valve stops the drooping under open throttle conditions, first discovered back in the '70s when non-return valves were hard to get.
- nigelrbfurness
TBG wrote:If your headlights sink low when you press the throttle your car definitely needs some TLC. Throwing money at Spyder is one way, but proper care and maintenance is another. Never had a problem in well over 200k miles.
I think I might have been returning from a 3,000 mile round trip to from Ireland to Budapest when I developed that problem. Otherwise the car ran well, it does get looked after
Sod's Law: If something can go wrong, it will go wrong, and usually at the most inopportune moment
In the absence of visible damage (eg crack in the T piece) I bought a vacuum / pressure gauge from Amazon.. A lot quicker to tell if you have a leak, than waiting a few hours for the pods to move.
If you attach to the T piece on the other side to the pipe that runs to the manifold, run the engine until you get a steady reading, then switch off the engine.. you get a pretty quick idea of which half of the system is leaking. Repeat as required at different points in the system. For me (+2, non failsafe) it is the pull switch that leaks... testing my repair in the morning.
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
If the leak is the pull Switch you can fit a Solenoid Valve like what is used in a fail safe. But plumbed in different.
- alan.barker
Users browsing this forum: Richardsona39 and 49 guests
