Number plate digits
PostPost by: fatboyoz » Fri Aug 21, 2020 7:47 am
Hi All,
After some replacement 3 1/8” (80mm) white, plastic numbers and letters with the clips to fit to the grill of my S4.
Perhaps, someone from the UK will know of a source who will sell the individual digits.
Colin.
'68 S4 DHC
fatboyoz
PostPost by: alan.barker » Fri Aug 21, 2020 7:50 am
Some have used "Framptons" in UK
PostPost by: fatboyoz » Fri Aug 21, 2020 8:00 am
Thanks Alan,
That was very quick.
I will email them and see if they will sell just the digits, and not just a complete number plate.
Colin.
'68 S4 DHC
fatboyoz
PostPost by: TBG » Fri Aug 21, 2020 8:18 am
TBG
PostPost by: MarkDa » Fri Aug 21, 2020 1:56 pm
I got mine from Matty.
Twice! As I misplaced the first set - they've never turned up.
I suspect that the carrier bag they were in just got thrown away!
MarkDa
PostPost by: alan.barker » Fri Aug 21, 2020 2:11 pm
MarkDa wrote:I got mine from Matty.
You need to question swmbo :oops:
PostPost by: MarkDa » Fri Aug 21, 2020 3:38 pm
I'm afraid that the simple question "Have you seen?" is usually interpreted as "what have you done with" already. So not something I do too often :D :D
MarkDa
PostPost by: 1owner69Elan » Fri Aug 21, 2020 4:24 pm
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: elancoupe » Fri Aug 21, 2020 4:50 pm
1owner69Elan wrote:https://www.tippersvintageplates.co.uk/phdi/p1.nsf/supppages/tippers?opendocument&part=2u
Good experience with Tippers. They shipped overseas quickly.
elancoupe
PostPost by: RichardHawkins » Fri Aug 21, 2020 8:02 pm
Colin,
I bought mine from thenumberplatecentre.com. If you are trying to get the “correct” item then you need to know that in the UK number plates were often fitted by the dealer who would use whatever was readily available to him. I copied what was already on my car.
Hope this helps,
Richard Hawkins
RichardHawkins
PostPost by: Robho » Sat Aug 22, 2020 2:16 pm
+1 for Tippers. £27 for seven digits, if I recall, including the spring clips to secure them. I chose silver finish, I think it was a little dearer than white.
Robho
First Gear
First Gear
PostPost by: tonyabacus » Sat Aug 22, 2020 3:51 pm
Tippers can supply all you need, they have been going since the 30's and have all the correct tooling etc.
Good for advice too.
tonyabacus
PostPost by: fatboyoz » Sun Aug 23, 2020 3:42 am
Thanks All,
Will use the information wisely.
Colin.
'68 S4 DHC
fatboyoz
Users browsing this forum: Richardsona39 and 29 guests
cron
