headlamp actuator adjustment S4
• Page 1 of 1
I have a Failsafe S4 Federal Elan. The vacuum actuator works - but won't for long if I keep letting the spring bend the actuator rod! I have it reassembled it with new metal turnbuckles. I successfully used zip ties to hold the spring compressed while I made the attachments.It is all connected with the center rod bracket extending forward, the spring curl facing forward and the rod-tube ends pointing down - sometimes - as it kind-of shows in the service manual. The turnbuckles are not yet adjusted because the pod connecting tube keeps flipping around and moving side-to-side etc. Is there anything other than the turnbuckles and the spring to locate and position the actuator tube? Did I forget to attach a critical part which would stabilize the tube position? Any suggestions would be appreciated.
Dick
0005K
Dick
0005K
- 0005K
- Second Gear
I don't have the failsafe system so I could be totally wrong here but I believe that the bar is located at either end by the headlamp pod inner pivot bolt which engages with the end of the bar with spacers to centralise it. SJ Sportscars in the UK lists longer inner pivot bolts for the failsafe set-up.
If it were me I would locate the bar first then attach the link rods to the pods and check the pods rise and fall properly before finally attaching the vacuum actuator and spring, that way you should avoid bending the actuator rod.
However, as I said, I have no experience with the failsafe system so hopefully someone will be along shortly to provide more accurate advice.
https://www.sjsportscars.com/parts-and- ... 0B0048.htm
Roger
S4 DHC
S4 DHC
- oldelanman
- Coveted Fifth Gear
Wow!
That would make sense. I'll look into it tomorrow. The actuation tube has smaller holes in the ends, so I suppose that a headlamp pod pivot bolt could continue through the body bobbin and enter the end of the actuation tube. I had not seen any reference to that in the shop manual or in the Brian Buckley book. Thank you Roger!
- 0005K
- Second Gear
It's been awhile since I had an S4, but Roger is correct that there is a bolt that passes through a bobbin in the headlamp pod and into the end of the cross tube on each end. Unfortunately the parts manual does not make that clear.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
- Third Gear
bitsobrits wrote:It's been awhile since I had an S4, but Roger is correct that there is a bolt that passes through a bobbin in the headlamp pod and into the end of the cross tube on each end. Unfortunately the parts manual does not make that clear.
Yes thats what happens on my failsafe PLus 2 in that it has two bolts to secure the link tube one through into the tube and one through the arm that comes off the tube at each headlight pod
rgh0 - Coveted Fifth Gear
rgh0 wrote:bitsobrits wrote:It's been awhile since I had an S4, but Roger is correct that there is a bolt that passes through a bobbin in the headlamp pod and into the end of the cross tube on each end. Unfortunately the parts manual does not make that clear.
The Elan appears to have adjustable links between the arms and the pods rather than being bolted directly as the Plus 2 is.
Roger
S4 DHC
S4 DHC
- oldelanman
The longer lower headlamp pod bolts worked like a charm! I used 2 inch long full thread bolts which went at least 1/2 inch into each end of the actuator tube. It was a clearance hole (not a threaded hole) in the ends of the tube.The tube is now very stable, and still has some cross-car room to move. The whole system takes quite a bit of adjustment and lock-down, but it seems to work once the swivel rods are adjusted. There is still some minor contact of the tube bracket at the spring attachment to the fiberglass reinforcement on the underside of the nose - but that was also there when I got it. I need to make sure that the pods still make contact with the stop-bolts at closed and open, so the pods don't rattle. I'll check it again after installing the heavy headlamps.
THANK YOU for the information I needed to get the headlamp pod actuation working!
Dick
0005K
Dick
0005K
- 0005K
- Second Gear
0005K wrote:I have a Failsafe S4 Federal Elan...............It is all connected with the center rod bracket extending forward, the spring curl facing forward and the rod-tube ends pointing down - sometimes - as it kind-of shows in the service manual. ...................
Dick
0005K
Reading this made me realise that my Spring was assembled the wrong way around. This is how the workshop manual shows everything:
This is how my car was assembled since I bought it in 2013:
The headlights used to take up to 5 minutes to raise! Although the Spring was torqued it was applying it's force almost along the connecting bar, so very little torque applied to raise the headlights.
Flipping the Spring around like:
The Headlights now come up quickly
Sounds like the OP now has their cross bar assembled correctly with the long bolts, but here is a picture of mine to show the turnbuckles etc:
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
• Page 1 of 1
Users browsing this forum: No registered users and 19 guests
