Plus2 Heater Cable Adjustment
Posted: Mon May 11, 2020 2:28 pm
Has anybody got any tips on how to adjust the heater cables on a Plus2S 130? I cannot seem to get the Hot/Cold lever to traverse from one end stop to the other. I can set it to be hard up against the HOT end (LHS) of the slider but as I slide it over to the COLD (RHS) it stops around 75-80% of the way across. I've fiddled about with the screw type adjuster at the heater end on the cable and also at the lever end but to no avail. The manual say, and I Quote "Should be adjusted to ensure the that the flap covering the heater matrix is fully open when the control lever is at 'HOT' and fully closed with the lever at 'COLD'."
The attached pictures show the Air Temp lever and the travel distance is approx 25mm. The pictures of the lever show it at the fully over to the LHS (when viewed from the dashboard) I.e. pulling the flap to the OPEN position, therefore hot. The red tape is simply a market. The other picture of the lever shows it in the fully to the RHS which would place the flap in the closed COLD position, The travel movement of the cable is approx 31mm. Hence the lever not being able to make the full travel from side to side. Any would be grateful if anybody has come across this issue and managed to fix it. Lastly, just to check could someone with a Plus2 confirm that the air temperature lever should have full movement from the HOT to COLD sides.
Graham
Graham
