Lotus Elan
Pedal play questions
PostPost by: monkeyodeath » Sat May 16, 2020 8:02 pm
Thanks for the tips. I'm going to try using an oilite bushing -- seems like a popular upgrade for the pedal bushings on other cars.
I think I'm going to cut out the old piece of tubing that the pedal and throttle cable arm were attached to, redrill the parts for a 1" tube and weld them together, then use an oilite bushing in between the tube and the shaft. Will post the results of my experimentation.
I'm tempted to just try to source an LHD box, so as to have the proper gas pedal, but this might work just as well and be a lot cheaper. Didn't really notice any downsides to the hacked-together pedal arrangement -- a little cramped, but seemingly doable.
monkeyodeath
First Gear
First Gear
PostPost by: bitsobrits » Sat May 16, 2020 8:09 pm
Check out bronze bushings.com. I've use them for several projects the last few years. No affiliation.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
Previous
