Re: clip on door mirrors
Posted: Thu Mar 05, 2020 9:38 pm
If using Tex door mirrors be aware that the fixing location on the doors will be different from side to side to enable a good view. The drivers side is easy to locate as you can sit in the seat and place it yourself, the passenger side will require an assistant to place and mark.
I can measure tomorrow the distance from the leading edge of the door to the front of the mirror mounts on my +2, from memory there’s at least a 50mm variation from side to side. I fitted my Tex mirrors in 2008, that’s 12 years ago and they work well.
