Re: REMOVING +2 BODY USING SCISSOR LIFT
Posted: Sat Oct 17, 2020 3:40 pm
Mike,
Only just got your message. I hope you’ve solved it now but if not here goes.
Take the load off the ratchet mechanism with the strap handle then carefully lift the pawl off the ratchet. Now lower the handle.
Reset the strap handle by pulling back its pawl then repeat above. You can normally drop by 3 to 4 ratchet teeth per go.
Safety note: DO NOT TRY AND DROP BY THE MAX POSSIBLE. IF YOU GET THE STRAP HANDLE OPEN 180 deg THEN THE MECHANISM GOES IN TO FREE RUNNING.
Hope this helps.
Dave
Hope this helps.
Dave
