Relpacement hard top window for S2
All,
In the process of restoring the hard top for my S2 and it appears that I'm going to need to replace the rear window as the current one is cloudy and scratched from many good years of service and then many more years in storage. Does anyone know of a source for a replacement, preferably in the United States?
-Ben
-Ben
1965 S2 26/4623
- benymazz
Check with a local airport small plane maintenance and repair facility. They have sources to replicate plexiglass windscreens. There is one on the West Coast, but I would think you could find one in your part of the country.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
I believe this is the company that Prezoom refers to:
http://www.aircraftwindshield.com/automotive.html
They do excellent work and have an enormous library of molds, particularly vintage cars.
An alternative would be to fabricate one of your own. It would involve making a plaster cast of your existing backlight. Then use a piece of new flat plexiglass laid over your mold, gently warm it in an oven so it slumps over your mold, then trim to finish.
Dan
Dan
Ben,
There is a company in St Augustine that can probably use your old one as a pattern and make you a new one of Plexiglass (acrylic). I just talked to a fellow there on Sat. They made a windscreen and headlamp covers fo my special Sprite (1960 Sebring class winner and '60 LeMans 16th overall, class winner etc). We can contact them once you're back in Fl.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Finding a oven big enough could be a challenge. I have seen it done by placing the form and the plexiglass in a box painted black and left out in the sun. Of course it was done here in the reclaimed desert they call Southern California.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
Such a long time ago but I'm pretty sure a had my perspex screen cut as flat from the original. The curvature is not great and it must have gone in without too much trouble. Sadly I have no idea of the source or cost as I don't have a complete bill archive.
Roy
'65 S2
'65 S2
elj221c - Fourth Gear
elj221c wrote:Such a long time ago but I'm pretty sure a had my perspex screen cut as flat from the original. The curvature is not great and it must have gone in without too much trouble. .
I agree, although not an original factory hardtop my screen was cut from a flat piece and I fitted it without problems.
