Can you spot the original ?
Posted: Fri Aug 02, 2019 10:19 pm
Here are two World Champion Car Constructor badges for a 69 S4.
Can you tell which is original and which is the repro?
There are obvious differences between the two. In particular the wreaths and the placement of the years within the wreaths. Fonts also slightly different on numbers and letters. Outer corners sharp on one and slightly rounded on the other.
I wonder if a Concours judge would pick up on this in judging originality.
Continues to confirm to me that if you can keep original parts, you are better off in terms of fit, finish, and originality. This badge is perhaps a minor case, but I have found this to be true throughout my original car. Refurbish and repair, as opposed to replace, if you can.
