back on the Lotus so questions arise: Battery tray
Posted: Fri Aug 02, 2019 7:10 pm
finally found the reason that I could not remove the rear seat to be a seat belt bolt completely hidden under the upholstery, picture below. The hidden bolt goes through the rear seat "pod" and into the chassis, effectively locking the pod in place. I found the bolt by feel rather than sight. The bolt on the other side was missing.
That out makes the reinstall of the petrol tank a bit easier.
I
The next issue was the rusty battery tray and the tinfoil patch behind it. Looks like a bit of the Rotoflex might have come off and put a hole in the fiberglass. At least the PO apparently replaced the joints. There is a second bolt, apparently unused and circled (a bit hard to see) to the left of the bobbin that holds the tray, also circled. Any one know what that's for?
The tray itself is curious. It fits nicely in the recess in the boot sub-floor, it is cleverly and securely fixed with a single bolt. But it certainly doesn't seem right. I'd originally planned to duplicate it with new material but I have second thoughts now. I is made from 3.2 mm angle or larger. Hard to tell with all the rust but there is nothing I've yet found on the car that heavy. While the fit seems good, the welding dies not. Perhaps a poor heavy gauge replica of the original? Picture below also. I know there was a previous topic on the battery box and some ideas for replacements but not much on the originals, no part numbers, pictures or descriptions. Perhaps someone has this information?
Tom
I
Tom
